Old 05-17-2020, 11:09 PM
Michaels76SE Michaels76SE is offline
Default I made an H.O. manifold....... I think
It started out as a 67 cast iron intake, did a gasket match which led me pretty far into the ports with a long bur and an equally long snap gauge, removed the exhaust crossover and the water crossover, cleaned it all up with a few different methods of metal removal and I'm going to paint it the same color as the early sixties super duty motors. My back hurts now.
ID:	540444   Click image for larger version
ID:	540445   Click image for larger version
ID:	540446   Click image for larger version
ID:	540447   Click image for larger version
Old 05-17-2020, 11:17 PM
Default More pics
More pics
ID:	540449   Click image for larger version
ID:	540450   Click image for larger version
ID:	540451   Click image for larger version
ID:	540452   Click image for larger version
Old 05-17-2020, 11:39 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Nice job! Huge amount of work! Did you happen to weigh it before/after?
Old 05-17-2020, 11:56 PM
Default I didn't weigh it.
it was an impulse task so I might weigh the next one. I also drilled too hard and put a hole in a spot where I also went too far with the grinder. Still a bit of welding repair before I paint it.
Old 05-18-2020, 08:41 AM
PDC PDC is offline
That looks really, really nice.
Old 05-18-2020, 10:49 AM
Tom Vaught's Avatar
Boost Engineer
Chuck Robers did a 1965 Cast Iron Tri-Power intake that way back in the early 80s and after it was cleaned and prepped, had it aluminized so it looked like the modern 1966 aluminum Tri-Power intakes being sold today.
GM Engineering made at least ONE 1965 Aluminum Tri-Power intake as I saw it first hand and held it in my hands. (Owned by a Collector of Rare Pontiac Parts). Nice work there but a Lot of Exercise involved, lol.
Tom V.
Old 05-18-2020, 11:01 AM
Tom V.
I've seen reproductions being sold for as much as 500 bucks
Old 05-18-2020, 12:45 PM
694.1 694.1 is offline
The port mis-match was quite surprising.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 05-18-2020, 11:04 PM
I figure Pontiac had an idea about getting port velocity with a certain shape of port in 1967. But it could have been core shift.
Old 05-19-2020, 07:32 PM
Donovan Donovan is offline
That's it, you got it.
Nice work.
If you thought you wanted to get the factory choke working again, you could buy a repro crossover and fit it.
I did one recently too. It's a lot of fun.
Old 05-19-2020, 07:41 PM
Nice work.
I think this manifold will only be used in special occasions with a Holley mechanical secondary and during the middle of summer. I'm currently staring at a set of cylinder heads to match for a target power band between 2500 and 5500 rpms.
Old 05-19-2020, 07:56 PM
I didn't port match mine, but did similarly.
Stock 68 intake started at about 43lbs and ended up at 27.5lbs without the water crossover
32.5lbs with. It would be 39-40lbs with the HO exhaust crossover included.
For random comparison, an RPM intake was about 17lbs
P4B QJ is about 14lbs
301 4bbl is 30lbs
Stock 71 HO aluminum is 14.5 without exhaust crossover
21.5 with crossover
The HO intake saved about 20lbs to a similar cast iron unit.
Old 05-19-2020, 07:59 PM
Nice...
When I ran my HO intake with the crossover blocked off, I converted to an electric choke. This worked well too.
