Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
WTB: T-II, Tomahawk, HSD... STOCK single-plane intake
Looking for a single-plane intake, with stock port openings. I currently have unported heads, so can't use anything that has been gasket matched to larger gaskets. I have a water cross-over, so do not care if yours has been removed or not.
This is going on a low-compression 455 in a Trans Am with shaker scoop, so can't use the taller intakes. I've got an efi system, and want to test a single plane with it. I'm in the Houston area (zip 77586). I may do a dyno comparison, if I'm able to find a few different intakes (maybe borrow from locals?). Thanks! vcxzrewq@yahoo.com if you want to contact me directly
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
I have an old T1 I would let go. I'm in Houston also. Sending PM.
I’ve got a HSD
I have a brand new hurricane that is powder coated and aluminum color .
Kevin |
I have just about every Pontiac intake there is. Not really interest in selling any right now but if you can not find what you want for your dyno test I can loan you some.
Have HSD, T1,T2, Tomahawk, Northwind, P4B, iron Q jet. Warrior. |
Lee you KNOW I have a selection to try But mine are opened up to RAIV at least -not sure on the RPM you used years ago on its port size. Tomahawk is opened some. New never bolted Holley SD I started porting the plenum not sure on the port size. A Warrior tunnel ram if you get crazy
I have a Holley Street Dominator if you need it. Are you looking to just test it and give it back? I can get it down there or send it to you.
'70 GP Model J 462 Butler ported 87cc Edelbrock D-ports RPM intake with Holley Sniper 2 CompCams 236/242 hydraulic roller Tribal Tubes tri-y headers TH400 13" Continental "Jim Hand Special" 3.50 9" CurrieTrac, 245/45-18 Front, 275/40-18 Rear |
O.K., a variety of offers so far - thanks guys!
It would be cool to do the testing, THEN decide which one I want to buy :-) For those offering to test: To simplify and expedite testing, I'll need to have the crossover removed. I'm willing to remove it, if you wish me to do so. Skip, if the port openings are stock or close to it, then I'm willing to test. Stephen, let me know when you can get it down here. Dragncar - let me see what I can source locally, then we can talk ;-) I'll get with everyone soon, thanks. If I can get this all together in the next few weeks, then I should be able to do the testing before the end of June. I'm open for helpers/observers as well.
Have a stock offy hi rise single four you can test, just cover the shipping it's yours. 37128 is zip.
Lee I'll measure the ports this weekend.
Thanx for the PM
Please post your findings. Kevin |
All at least RAIV/1233 port sizes.
just quick update, I had an accident, emergency surgery on right hand, probably another in a few weeks. probably no testing for a couple months. or posting, hard to type one handed :-(
Sorry to read this Lee. Hope you have a speedy recovery and get that hand 100%.
Lee if I had known I would have given you the name of the surgeon that put my right hand back together after a bad dog bit at work last Monday! Hope you get better soon man! let me know if I can help you.
thnx guys! speedy recovery to you too Skip!
I have a stock T-II with port injection if it comes to that.
It has rails but no injectors. Although I live in Austin now we occasionally drive out your way. Speedy recovery to You and Skip as well. |
have a brand new T-1 taking up space
