1969 Firebird parts, Rally Gauges, Kick panels, etc
Rallye Gauges - Good condition, everything works - $175
Clock - Doesn't work, easy fix, nice clear plastic, no cracks - $50 Kick Panels - Good condition, black, vents work, scratches near ebrake - $125/pair Complete Pulley Set - Early '69, short pump, hard to find - $225 - matching used water pump - $25 Distributor - works, good newer cap - $25 Fuel pump - carter, stock style, newer - $25 Taillight housings (2) - good condition $50/each Taillight lens (1) - driver quality - $25 Taillight chrome bezel (1) - driver quality - $25 Headlight cushion (1) - driver quality - $25 Window Regulators - Fronts, Std Int. - $75/each Complete Seatbelt set - Black, Driver quality, could use thorough clean and reconditioning - $100 |
you have a PM..
1969 Pontiac Firebird 400 - Candy Green 1977 Pontiac Trans Am 400 W72 - Black |
PM's replied to.
The seatbelts are black in color. The Distributor number is 1111942 8G30. This is correct for a 1969 Firebird/Tempest with a 2bbl and Auto. Date code is the 30th, 1968, but not sure of month. I'll post pulley #'s this weekend. Pulley set includes Alternator, WP, Crank, P/S and the little round spacer plate for the crank. I also have a factory Balancer, but looks like some wear at the front seal. Also for sale: 350 Nodular Crank - $75 350 Pistons and Rods, good shape, .030 overbore. These are stock rods and Badger replacement style cast pistons - $100 Last edited by Josh69; 04-16-2010 at 10:10 AM. |
Hi Josh if the kick panels are in Good shape I am interested,can you send some pix?Also I would like a pic of the gauges.
Thanks Ralph |
Sorry for the delay, thought you sent a PM! I will post pics of the kick panels this weekend.
