pushrods rubbing??
So after assembly on my 461 we noticed my pushrods are rubbing on my edelbrock heads. I thought they were supposed to clear 1.65?? Anyone else have this issue?? I am running solid roller and harland sharp 1.65 rockers. Pushrods were measured and ordered the correct lenghts
What dia push rods?Tom
My 1st gen edelbrocks rubbed at the bottom of the tubes quite a bit with a flat tappet cam. 5/16 rods thought I was the only one Rod
You got two choices, remove the heads and have the pushrod holes enlarged or switch to 1.5 rockers. I can understand your frustration as you would think the heads should clear.
Tim Corcoran |
Yeah i already have It apart and going to To open up the holes. Its just crazy everyone I have talked to says there's clear
How much is safe to remove?
Tons of meat there at the bottom ,you can grind off a easy .060" with room to spare
Ditto. Had to clearance the sides on a couple of the holes on my 2nd gens when I put them on my aftermarket block. Still running a flat tappet.
74 GTO Bracket/Street car and another 74 for the wifey to race with! 70 GTO 400, 4 spd, #'s matching and a little to nice for me to own. Friendship is like peeing your pants..everyone can see it but only you can feel the warmth! |
A sight rub won't hurt anything and will also help control flex.
It's not a slight rub once I really watched it. It was almost flexing the pushrod. Do the Louis tools work on the e heads
Careful. I had the same issue with my High Ports (but at the top of the pushrod hole) when I changed to a higher lift camshaft. Cost me broken lifter bore and junked a block I had 2K in.
Todd Sedlmeier Who ever thought pinewood derby cars would lead to this! October 2004 HPP Shootout participate http://www.highperformancepontiac.co...out/index.html 86 Grand Prix 535 High Port 8.93 @ 153 65 GTO 433 High Port 12.04 @ 113 |
What wall pushrod? Spring Pressure? I have seen allot of pushrods rub the head due to the pushrod flexing.
66 GTO Nostalgia Super Stock/Street Legal Car 421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99 Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
1-Piece .083 X 5/16 .040 Oil Restricted Chromemoly Pushrods
440 lb spring pressure |
That kind of pressure i would be using .116 wall, IMO
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's |
X2^^^^ A friend of mine had such bad push rod flex it looks like the push rod was touching the head the hole way down. There was a thread on here somewhere. I went to 3/8 manton push rods. Heads had to be clearenced and new guide plates.
Agree, that is why I asked the thickness. Had the same issue the op is having using .083. Changed to Smith Bros .116- problem gone and the car picked up .10
