1970-73 Trans AM/Firebird parts
NOS wheel spoilers $200 ea, 73 core support $350, NOS front steel valance panel for 73 firebird $300, T/A hood $300, complete oxblood interior for 73 firebird/TA $300, 10 bolt posi rear (drum brakes) 3:08 ratio $275, endura bumpers for 73 firebird $200 ea, Global West solid body mounts (all 6) $85, 73 Upper and lower A-arms with Global West Del-A-Lum bushings installed, never used (all 4) $ 295. Please contact Chris @ 717-624-2039
ill take the nos wheel spoilers, core support, and steel valance , body mounts, upper and lower control arms- and follow this up with a call in about an hour, - Scott
77 400 4-SPEED SE HARD TOP,,, I know... where did you get it.... |
Interested in the 73 Interior could you give more details please.Dash?Seat belts? Overall condition?
Are the endura bumpers for 73 same as 71? Is one still available? NOS or used? Straight?
Thanks! Sam
-- Sam Agnew Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it. Ministry - Jesus Built My Hotrod |
for info,No the 73 bumpers are different than the 70-72 bumpers.
FREEDOM ISN'T FREE BUT WORTH FIGHTING FOR |
Just to add to what warbird said....the brackets that hold the 73 nose are different too, and switching years on a car is not an easy task.
Since we're on the subject (and since I'm looking) do I need to stick to 71 or can I use 70 or 72 front or rear bumpers? Looks like these are not reproduced parts and I need to hunt for used items.
There is at least one post on rear bumpers for 70-73, and I am sure its in the 70-73 bird tech section. Try doing a couple of searches there. In any case, its the 73 setup that again is different. Cant remember for sure, but it MIGHT be just the brackets that are different.
The rear bumpers are the same from 70-73 only the mounting brackets changed in 73, these brackets moved the bumper further away from the body. Chris
