Putting 455 together - Cam Plug in too far
I did the dumb thing.. I put the plug in before the cam. Searched and Read a few old posts AFTER CAM,, that this is a rookie mistake.
Front of Cam then wouldnt go in past the front block face. It was hitting plug. Was tempted to use cam to push it out but it was way too pretty.. Got a long 3/4 pipe, rolled it in thin foam packing sheet , put a 3/4 to 1' adapter on the end wrapped that in gaff tape and poped it out. Had to put motor back on hoist... to do so. Waste of time... Got 2 (1 extra) 2 1/16 plugs, this time shallower brass plugs. Put cam in, verified that flush would give me good clearance Set it flush, Blue Locktite. On to measuring main main bore clearances, Ring gaps and smoothing piston tops with scothbrite and cleaning pre install. Hope to get this thing together soon. Lesson learned. This site has taught me lots. Often I just learn in the wrong order..
-- James Work '67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake." '75 Formula 400 - Daily Driver - Running with my Home Built 455 and TH400 Details here: http://forums.maxperformanceinc.com/...d.php?t=588372 |
Nice going..............
Well thought out fix for a somewhat common mistake; well done, James .
Les
Les Iden ---------------------------- '65 Buick Sport Wagon Custom, 340, T350, 3:23 '66 GTO Post/468, 700R4, 3.31 (Mike's as of 9-16) '68 Grand Prix/455, dual AFBs, T400, 2:93 posi (sold) '72 TA tribute/461, T400, 3.08, (Russ's as of 9-16) '97 Mitsubishi Eclipse Spyder Turbo, Konis, 5 speed '09 Torrent GXP, nav, Sun & Sound pkg., Bilsteins |
Good stuff James. Sounds like we are going through the same process, except for the rear plug. I did the piston tops yesterday. Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi. “Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill |
