Old 01-24-2021, 11:16 AM
grandam1979 grandam1979 is offline
Default Speedmaster on HRG
Did anyone else see this episode this morning? Put heads on a 454 with Speedmaster rockers and hardware. Said they paid like a $1050 for the set. Engine made 472 hp 473 trq it will interesting to see how long it last as is. They are putting it in a 74 vette so should be fun to see how it goes for them.
Old 01-24-2021, 01:18 PM
grivera's Avatar
grivera grivera is online now
Yep - great episode and I started late. Didn't catch what cam they put in the engine.
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 01-24-2021, 02:15 PM
I think it’s a comp hyd roller .550 lift if I remember right they give the part number but I didn’t catch it.
Old 01-24-2021, 02:17 PM
ponjohn's Avatar
ponjohn ponjohn is offline
HRG?
Old 01-24-2021, 02:22 PM
1968GTO421's Avatar
Originally Posted by ponjohn View Post
HRG?
Hot Rod Garage
GTOAA--https://www.gtoaa.org/
Old 01-24-2021, 02:26 PM
I looked it up it’s a baby hyd roller .547/.547 230/236@.050
Old 01-24-2021, 03:29 PM
ta man ta man is offline
So they made just over 1hp per cu inch....yawn..switch channels..
The Following 2 Users Say Thank You to ta man For This Useful Post:
Old 01-24-2021, 04:18 PM
scott70's Avatar
scott70 scott70 is offline
Right,,cripes I made 490hp 570trq with 462 cubes,iron intake,iron #64 heads, qjet,9.7 to 1 comp and a ra4 size hft cam. Peak hp at 5200 rp.s.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 01-24-2021, 07:37 PM
Formulas Formulas is offline
Huge upgrade over the original 1974 Vette engine, They probably weren't focused on pro mod performance but something to put alot of miles on in a frugal manner
People do that
Old 01-25-2021, 10:59 AM
They picked the vette for emissions in California.
Old 01-25-2021, 11:01 AM
That’s funny you just told every guy in the forum his 455 that didn’t make well over 500 hp has boring junk. Nice
Old 01-25-2021, 02:58 PM
nachomax's Avatar
nachomax nachomax is offline
1975 and older vehicles are emissions exempt in California.
Old 01-25-2021, 03:14 PM
Definitely didn't intend to make it seem that way. I guess the better way to put it is ....472hp with a BBC with aluminum heads is pretty lame..when a stock appearing Pontiac engine..or a BBC can put out the same power.
One of my own personal favorite engines I had was a 455 with 6x 4 heads crower 60919 cam rhoads lifters and 1.65 rockers..great engine and certainly not boring and not even close to 500hp.
Is there a link for the episode ? I'm curious on the carb intake choice.
Old 01-25-2021, 03:48 PM
1968GTO421's Avatar
I have to concur, my brother some years ago had a 454 with iron retangular heads and a mild HFT cam that dynoed just over 500hp; not a big deal. I would expect Street Master to do a tad better than that or why would anyone pay good money when factory heads can get you there much cheaper (or free if you already have a good set). Just sayin'
Old 01-25-2021, 04:24 PM
Formulajones's Avatar
I haven't seen the episode and there hasn't been any mention which streetmaster head they used. Their site lists a few. Interestingly they don't publish any flow numbers that I could find. I'm going to guess they aren't stellar.
The 230 cam is a baby cam for that size engine, so I'm guessing this thing doesn't have any compression either, and no mention of intake/carb used?
You can make 500hp all day long with a BBC and stock iron heads. This isn't doing Streetmaster any favors.
https://youtu.be/XqEydRRRwqE
Old 01-25-2021, 05:52 PM
72projectbird's Avatar
That sucks. You can't have any fun past 75
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 01-25-2021, 06:03 PM
It's an improvement from the way it used to be. I remember when they were going back to 1967, that REALLY sucked! And that wasn't all that long ago either. I think they moved it up to 75 only several years ago. I had to have my 70 Formula tested over there. It's a racket for sure.
Old 01-25-2021, 09:31 PM
Schurkey Schurkey is offline
But it DOES confirm that HRG can be bought. They'll promote any product that provides enough cash up front.
Therefore, they're worse than a useless waste of time. They're got no ethics..
Old 01-25-2021, 10:06 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
We still have the 1967 issue down here in Maricopa County, AZ (Phoenix). I have to take my (daily) 71 GTO thru emissions every year. Needless to say, it's a stock set up. My others I can play around with more as they live on classic insurance policies.
Eric "Todd" Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
'67 Tempest Wagon (428/TH400/2.56 posi)
Deuteronomy 8:3
Old 01-25-2021, 10:11 PM
Yeah, that's one of the reasons I'm up here in Prescott. Nothing here.......yet, lol
The stuff that matters I keep classic insurance on anyway but yeah, I know what you mean.
