69 firebird v8 clutch return spring extension
Hello I am trying to organize a group buy for 68-69 firebird clutch return spring extension for vehicles with Pontiac v8s . the original part# was 9785884 and was supersceded by 9789817 (which ever came first). they make them for 6 cylinder and small block cars but not Pontiac v8 cars. Hopefully we get enough response for Admin 5 or Ccas to look into it. thank you
rick craffey |
I'm in for a pair of these if you can have them made for a reasonable price. Do you have an original one to use as a pattern? My problem is I don't have an original to copy. From diagrams I've seen, they look pretty simple. We could probably have some hand bent that would be pretty accurate. I think all it would take is one of those wire bending tools. Regards, OJ |
Unfortunately I don't have one for someone to copy. With some luck somebody on this forum has one. |
I need one also.Maybe Mark S. or Matt has one to copy?
I have the original one from my T/A that could be used as a pattern if you could convince someone like Norwood to copy it and make sure mine is retuned.
If for some reason you and Rick can't make this work, maybe just some close up pictures and some dimensions would do the trick along with the diameter of the wire.... I really think I could bend my own if I had that info, but I would still be happy to pay a reasonable price for someone else to make an exact copy or two for me. Thanks so much for helping in this cause. OJ |
I would be interested too.
68 400 HO 4sp Convertible Firebird400HO.com My 68 firebird 400 HO convertible Restoration Gallery |
If you guys are referring to this return spring bracket that bolts to the sub-frame on a 69 Firebird, a high quality reproduction has already been done. The correct style return spring is NOT available anywhere.
I was talking about the wire extension that goes between the spring and that bracket.
The link below shows it. Scroll down to Page 30, item #11. http://www.teufert.net/partbook/67-76/0-i.pdf Regards, OJ |
Resurrecting this .. how about some pics?
Folks,
I'm bringing this back up as I really need one of these clutch return spring extensions. All I need is a few photos of different angles along side a 12" ruler so I know how big to make the bends. That will allow me to make at least one for myself and maybe more. So, please, anyone who has an original part, please help us all out with some photos with dimensions. Thanks OJ Quote:
Did anyone make one for them self yet?
I'm also interested in seeing pics/dimensions. Will be assembling all this stuff in the coming months on my 68.. Thanks in advance for your help...
http://forums.maxperformanceinc.com/...d.php?t=804117
Extension
Anything ever come of this?
