Old 06-28-2014, 10:27 AM
bjohnson's Avatar
bjohnson bjohnson is offline
Question New body panels that come painted black.
On new body panels and parts they come painted black. i was told once its like a preservative. What is it called? After soda blasting a car body clean should a guy have it painted with this stuff? Any other advice?
Bruce Johnson
1970 GTO VOE HUMBLER
Old 06-28-2014, 03:21 PM
NBF823's Avatar
NBF823 NBF823 is offline
Stuffs called EDP primer. Opinions vary. I like good mechanical adhesion.
Jon B
Old 06-28-2014, 06:26 PM
Fishin2Deep4U's Avatar
Fishin2Deep4U Fishin2Deep4U is offline
And some of it is better quality than others. If it's really stuck, you can scuff and shoot. I have seen it comes of easily as well. I tend to take it to bare metal and epoxy prime.
Dave
'68 Bird Vert, 455 , 6x-8, 1.5 HS, HEI, PPR TC-02-HF, TH400, 2500 Hughes, 2.56 8.2 (getting swapped for second gen with shorter gears)
Fishing guide in the Washington state for Salmon, Steelhead and Sturgeon. Fish-On!
Old 06-29-2014, 05:59 AM
bjohnson's Avatar
Thank you for the info NBF823!!
Bruce Johnson
Old 06-29-2014, 06:01 AM
bjohnson's Avatar
Thanks Fishin2Deep4U. Much appreciated!!
Bruce Johnson
Old 06-29-2014, 10:31 AM
irgoatmike irgoatmike is offline
One good way to check the edp quality is to wipe a little lacquer thinner on it. If it wipes the black primer off, remove it all. If it doesn't, sand and prime/seal. Irgoatmike
Old 06-29-2014, 01:15 PM
I have seen it hold up to thinner but have poor mechanical adhesion. We used to use some carpet tape and pull test the coating. But ran out of thatsuper stickystuff and have not found a good replacement. We usually scratch test now and more often than not, it all comes off for sand and epoxy.
Dave
