Old 03-17-2021, 01:19 PM
ignaro's Avatar
ignaro ignaro is offline
Default How to route positive battery cable to starter?
I've got my new 461 in the 66 Tempest, headers on. Went to install the starter last night and it's a very tight fit but it's in there. Since this is my first Pontiac motor, how do you route the positive battery cable up into the front of the starter? Does it clip to the crossmember? Obviously I don't want it to be too near the headers and a ground!
I will be installing the battery in the trunk so I can have the cable come through the firewall/floor wherever makes sense. I can't imagine how I'd do it with a normal battery tray.
I know a mini starter would help with this and heat soak but it's not in the budget right now. Trying to just get it running.
Sent from my SM-G988U1 using Tapatalk
Old 03-17-2021, 01:22 PM
68lemans462's Avatar
68lemans462 68lemans462 is offline
The (+ ) batt cable usually runs along the oil pan and then up the front of the engine to the battery. There were a couple different brackets/tubes the factory used. The (-) cable attaches to a head bolt stud, or another threaded hole in the drivers side cylinder head. I'm unsure how this would work with a batt in the trunk.
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
Old 03-17-2021, 02:19 PM
ignaro's Avatar
Ah, along the oil pan rail, where it mates to the block? Are there clips or something? I was thinking I'd drill and tap my crossmember to put a little wire/hose clamp in there but that sounded crazy.
Old 03-17-2021, 02:36 PM
gtospieg gtospieg is offline
You need part # N179EK(battery cable heat shield $34). This is bolted to the driver side motor mount. You have to drill and tap the mount. You will also have to bend the battery cable where it comes off the starter(90*) for max clearance. In order to install it you will need to drop the starter and attach the cable after first running it through the tube that is attached to the motor mount.
Old 03-17-2021, 03:46 PM
1968GTO421's Avatar
Here's the site:
https://secure.amesperf.com/qilan/De...A&web_access=Y
GTOAA--https://www.gtoaa.org/
Old 03-17-2021, 04:17 PM
Old Goat Racer's Avatar
Nice flywheel !
Everybody knows somthin.
Nobody knows everything !
Old 03-17-2021, 05:17 PM
ignaro's Avatar
Originally Posted by 1968GTO421 View Post
Thanks!
Old 03-17-2021, 07:06 PM
ponjohn's Avatar
ponjohn ponjohn is offline
I would use a ford solenoid.
The Following User Says Thank You to ponjohn For This Useful Post:
Old 03-18-2021, 07:59 PM
Originally Posted by Old Goat Racer View Post
Nice flywheel !
Lol, it does look like it’s on backwards!
Sent from my iPad using Tapatalk
2007 Grand Prix GXP 5.3L
Old 03-18-2021, 09:36 PM
Appears to be that way doesn't it.
Is this a fresh build with the engine/flywheel/starter/bellhousing?
I got away from the stock tube thru the exhaust manifold on my 64 GTO and went to the 67+ style, (go under the manifold/ (headers in my case), along side the block and then down to the starter.
The Following 3 Users Say Thank You to Tom Vaught For This Useful Post:
Old 03-18-2021, 10:56 PM
ignaro's Avatar
Aw crap, is it on backwards? How embarrassing!
Yes, fresh build and my first. Not my first mistake in all this if I did put it on backwards... Here's hoping there aren't others
Old 03-18-2021, 11:41 PM
ignaro's Avatar
Oh man, you guys had me freaking out. I really don't want to yank that motor again. I watched a Ram clutch install video and the flywheel teeth are on the motor side, not the clutch side. I pushed the starter gear out and it seems centered on the flywheel teeth. I think I'm good, right?
More pictures attached. Ram 1557 flywheel and Ram 11" powergrip single disc clutch.
Old 03-19-2021, 06:45 AM
Picture is worth 1000 words. Yep, you have it on correctly.
Sometimes a picture can be deceptive. Why made the flywheel?
Looks like a nice one. One nice thing about a stock Bellhousing, you can see the flywheel/clutch parts from the bottom of
the bellhousing if the metal shield is not installed..
Old 03-19-2021, 09:37 AM
ignaro's Avatar
Thanks for confirming!
Old 03-19-2021, 03:32 PM
SRR's Avatar
SRR SRR is online now
https://www.youtube.com/watch?v=L2Aurj3YoxY
I know, I know. BUT I do this on all my older cars to get a way to remote crank my engine AND get that live battery cable away from all the hot things.
Name:	Ford solinoid conversion.jpg
― Calvin Coolidge
The Following User Says Thank You to SRR For This Useful Post:
