Old 11-02-2015, 09:14 PM
Mr. G Mr. G is offline
Default Core support bushings for 1971 GTO
Need to replace the core support mounting isolators or bushings or whatever they are called. Need to know who makes the best ones out there. Thanks!
Old 11-03-2015, 12:13 PM
tripower's Avatar
tripower tripower is offline
Don't think anyone has gone over the nuances of radiator support bushings since they are typically crushed under the washers when the bolts are tighted. I think you buy a kit with the washers and bolts. Ames has the correct bushings in their kit.
Typical problem is rot-out on the core support holes where the bushings mount. New bushings won't do any good if these holes enlarged from factory size. There is a repair kit they sell if need be.
Norm J
Old 11-03-2015, 04:51 PM
Thanks. I have them on order.
