68-72 GTO Mostly - NOS/Reproduction/Original parts leftovers from Project
I am finishing up on the 69 GTO project and have a bunch of items from the restoration/collection I am never going to use as I dont plan to restore another car Im done after this one. Hopefully someone currently restoring a car can use this stuff as most of it is priced at half or more of what I paid excluding the NOS items. I will work with you on multiple items purchased. Tried to list items in Lots to minimize shipping.
Prices do not include shipping. All parts located in New Kensington, PA Payment via PayPal F/F or USPS Money Order Ask any questions or if you need additional pictures etc. please let me know. Pictures to follow... NOS Parts 69 NOS GTO/Lemans Grand Prix Washer Wiper Switch (Super Nice) - GM #1993449 - New in GM Box - $275.00 69 NOS GTO Rear Quarter Marker Bezels (2) - Chrome is typical GM on these - (No Box) - $50.00 Both 69-70 NOS GTO/Firebird Judge Ram Air III, IV Pull Knob Decal Ram Air GM #382117 In GM Packaging - $175.00 69-70 NOS Radio Fader Switch GM #7309422 - New in GM Box - $125.00 68-72 NOS Rear Floor Plugs - 1" Opening (Embossed) GM #4410574 In GM Packaging - $50.00 69-70 NOS (Firebird/Camaro) Brake Pedal Pad (No Park) GM #3945593 In GM Packaging - $15.00 67-72 NOS (Firebird/Camaro) License Plate Lens Gasket GM #5955194 - In GM Packaging - $10.00 68-72 NOS Ignition Lock Cylinder Sleeve GM #7024624 New in GM Box - $20.00 68-72 NOS Wiper Motor Cover GM #4918070 (Depressed Park Cover) - New in GM Box - $35.00 69-70 NOS Wheel Well Molding Screws Correct GM #588546 - Bag of 10 Unopened in GM Packaging - $45.00 68-72 NOS Oil Pan/Block Screws GM #3846202 - NOS in GM Package - Have D Embossed head - Qty 4 - $25.00 68-69 NOS Antenna Base Bezel - GM #9791580 - No Box/Packaging - $25.00 69-70 NOS Radio Rear Speaker Knob - GM #9784339 - Check Application/See Pic - $35.00 69-70 NOS Radio Tone Knob - GM #9786943 - Check Application/See Pic - $25.00 68-72 NOS Emergency Brake Cable Clip - Holds the EB cable at the frame front (1) place (No Packaging) - $5.00 70-Up? NOS Differential Bump Stop (Pinon Bumper) GM #535757 - Unknown Model/Application - $15.00 68-70? NOS Cigarette Lighter - GM #7033244 - Possibly Grand Prix?/Unknown (See Pic) - $10.00 69-70? NOS Horn Contact Insulator (4) - GM #382117 Needed to use Original Cancel Cam to Sport Wheel - $30.00 All These are tough to find NOS for 71/72 (Need Blasted/Painted/Plated) - $125.00 for Sleeves and Clamps 71/72 - NOS Tie Rod Adjustment Sleeves GM #5668674 - Qty 2 - In Saginaw Boxes 71/72 - NOS Tie Rod Adjustment Sleeve Clamps GM #5668675 - Qty 4 - In Saginaw Bags NOS Flashers - I believe these are correct for older models 60-66? (Please Check Application) NOS Directional Flasher - Tung Sol 323 Yellow GM #383637 - Plastic "DOT" - 3 Lamp (Date 2 3 0) - New in Box - $25.00 NOS Directional Flasher - Tung Sol 323 Yellow GM #383637 - Metal - No DOT - 3 Lamp (Date 3 2 0) - New in Box - $25.00 NOS 68-72 Lower Control Arm Bushings - $100.00 All 68-72 NOS Lower Control Arm Bushing (2) - GM #9778357 - Small Round Front - Harris 62234 68-72 NOS Lower Control Arm Bushing (2) - GM #9792687 - Large Oval Rear - Harris 62541 68-72 NOS Lower Control Arm Bushing (1) - GM #9778357 - Small Round Front - Harris 62234 Reproduction Tie Rods 68/70 Inner Tie Rods In-Line Tube (INL11194) - Qty 2 - (Retail $118.00 Pair) - $60.00 64-70 Outer Tie Rods Ames/Moog (S107/ES333RL) - Qty 2 - (Retail $98.00 Pair) - $40.00 Reproduction Lot A All Items - $125.00 69-70 Ram Air III Pre-Heat Shroud (Painted) The Parts Place (EX2255Z) (Retail $79.00) 69-70 Ram Air Pan Hose Kit w/Union and Coupler - Upper Pan Ames (N174PN) - (Retail $12.00) 69-70 Ram Air Cable - Pan to Scoops (Late Style Coated) The Parts Place (CW4637Z) - (Retail $35.00) 68-75 Vacuum Actuated Heat Diaphragm (2) No Brackets The Parts Place (CB8422Z) - (Retail $40.00) 65-72 Sport Wheel Horn Switch Ames (A248R) - (Retail $19.00) 69-72 Sport Wheel Switch Adapter Ames (A248F) - (Retail $18.00) 67-68 (Firebird/Trans/Am) & 68 GTO/Lemans - Speaker Lead Front Letric Limited (33422) - (Retail $29.00) 72-89 (Firebird) - Rochester Cigarette Lighter Element Housing #7028145 (Retail $24.95) 70 Fuel Tank Vapor Filter w/Hose In-Line Tube (INL11407) - (Retail $29.00) Reproduction Lot B All Items - $100.00 68-72 Carpet Toe Plate Ames (A228) (Retail $23.00) 68-77 Differential Bump Stop (Pinion Bumper) - Embossed In-Line Tube (INL11295) - (Retail $14.00) 69-70 Speedometer Cable Upper Cable - (for 2 Piece Cable) - 45" NOS Ames (R158J) (Retail $55.00) 69-70 Speedometer Cable Lower Short - (for 2 Piece Cable) - 12" Deluxe Speedometer (Retail $65.00) 69-72 Speedometer Cable Hold Down Clip/Screw In-Line Tube (INL12802) - (Retail $4.50) 69-70 Dash Pad/Lower Cover Nylon Nut - Quantity 15 - GM #1373789 (Retail $10.00) 69 Fuel Tank Vent Tube and Clamp w/Screw Ames (L222HT) - (Retail $29.00) 69-70 Fuel Tank Vent Tube Grommet Ames (L222CG) - (Retail $12.00) 69-70 Fuel Tank Vent Tube Grommet Ames (L222CG) - (Retail $12.00) Reproduction Lot C All Items - $100.00 64-77 Pontiac Valve Cover Grommet In-Line Tube (INL10308) - (Retail $4.00) 64-74 Alternator POS End Cap Retainer - Red Plastic Ames (M250KR) - (Retail $4.50) 64-72 Horn Contact Kit - Ames (A248P) (Retail $5.00) 68-70 Hood Latch/Release Rod /Pull Handle Grommet Ames (D179G) - (Retail $5.50) 64-77 Rear Drum Locks (4) In-Line Tube (INL10121) (Retail $8.00) 69-70 Pontiac GTO Engine Block Decal YS Code In-Line Tube (INL10149) - (Retail $4.75) 68-72 V8 Intake Vacuum Fitting Brass In-Line Tube (INL11220) - (Retail $14.00) 68-70 Choke Thermostat/Choke Rod In-Line Tube (INL11759) - (Retail $8.00) 68-69 Bumper Outer Snubber Clip Bracket Bolts (4) Ames (L176J) - (Retail $6.00) 69-72 Pontiac GTO Ram Air Exhaust Bolts (5) In-Line Tube (INL11142) - (Retail $10.00) 68-72 Hood Rear Bumpers (2) w/Screws Ames (D115C) - (Retail $9.50) 69-72 Glove Box Rivet Set (6) Ames (A353R) - (Retail $2.00) 68-72 Short Tire Valve Stems w/Dill Caps (5) Ames (T100BB) - (Retail $12.50) 67-72 Correct Coat Hooks (2) No Screws Ames (A395P) - (Retail $12.00) 68-79 Core Support/Radiator Support Brackets/Bolts In-Line Tube (INL11147) - (Retail $14.50) 68-72 Trunk Lock Retainer Plate - Retainer/Screw - In-Line Tube (INL14417) - (Retail $16.00) 64-77 Tie Rod Sleeve Bolts - In-Line Tube INL-11920 - Qty 4 (Retail $10.00) 64-72 A-Body Side Hooks (Floor Pan to E-Brake Cable) - In-Line Tube (H0010) - Qty 2 (Retail $8.00) 64-72 Rear Control Arm Brake Cable J Hooks In-Line Tube (H0012) (Retail $10.00 Pair) 68-72 Bucket Seat Knob - Chrome (Metal) - Legendary TA67GA-KNOB - Qty 2 (Retail $20.00.) 68-72 Duct Seal Non-AC - White Caulking In-Line Tube (INL10459) - (Retail $8.00) 68-72 Blower Motor Cover Kit w/Clips/Screws Etc Unknown Vendor 68-72 Floor Drain Steel Plates - Qty 7 Ames (A217WK) - (Retail $31.50) Original Parts 69 4 Speed Linkage Bolt/Backdrive Stud - GM 9795597 (Tough to Find Original) - $50.00 69 Courtesy Light Bracket Original that has been Re-Plated - $10.00 69 Park Lamp Housing - No Rust/No Pitting - Great Condition - $100.00 68-72 12" Armrest Bases - L/R - Re-Dyed - Good Looking Set - $40.00 68-72 Spare Tire Hook - Blasted/Painted - $15.00 69-70 Horn Relay Metal Cover Original that has been Re-Plated - $10.00 68-70 Original - T3 Lamps (Tested) - High Beam 2/Low Beam 2 - Very Nice - (Great for Survivor Car) - $75.00 |
NOS Pics
NOS continued
More Pics...
The Following User Says Thank You to taf44667 For This Useful Post: | ||
Continued..
more...
more.....
more......
more.
Flashers
more.....
Reproduction Lot A - Pics
Reproduction Lot B - Pics
Reproduction Lot C - Pics
Original Parts Pics..
More original pics..
T3 Pics...
end of pics....
Forgot the bases...
I would like to buy the 9778357 bushings. Are the all in the same condition as the one in the pic?
