Cruise control vacuum release valve
1978 Pontiac Trans Am
Probably a silly question but... My factory cruise control vacuum release switch that is mounted to the bracket in front of the brake pedal makes a loud audible "click" every time I step on the brake. It operates perfectly but I find it rather annoying. Do they all make the loud click or is mine just noisier than normal? |
Mine does not click
1977 Trans Am 400/4speed (swap) Brian |
Nor does mine
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
Here’s both switches in GM, nOS, no click on either. Remove both, see where the click is.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8” Flakes pause pause F ire B irds 🇮🇱 |
The top one in the picture is the one clicking. It's the vacuum release valve.
I removed it and found that it is somewhat slow to release and when it finally does it clicks loudly. I tried to clean it up and see if the release action got any better but it didn't. A quick search showed that these switch valves are not readily available and not exactly inexpensive when you do find them. I may just have to live with the click. Thanks everyone. |
I forgot to mention that I’m also planning to apply a little silicone lubricant spray to the inside as well to see if the rubber seal softens up a bit to slide more freely in the plastic tube. I hope it works!
Well, silicone lubricant spray was definitely not the answer. It actually made it worse. However, after a few dabs of white lithium grease on the inside, it's as good as new...no more clicks!
I’d just replace it. I just picked up these to have just in case. You can prob get an A-M one pretty easy at the auto parts store.
Yep, you were right. Just replace it. It started acting up again just a few days later. I found that a vacuum release switch for a 1982-1983 firebird (SMP-SLS234) worked just fine in its place and is readily available. It just adds an electrical connection that I'm guessing is to cut power to a TCC solenoid when you step on the brake? It still fits fine though. Thanks!
I can prob find you a used one, Leme know of you want one still. I found a whole nOS dealer install Cruze kit at Dayton, kept the switches and the 2 spedo cables, sold off rest, I like having spare parts on hand just for problems like yours that pop up
