455 is alive!!!
Dudes,
I just fired up my new 455 in my 71 Lemans convert! Awesome sound! oil pressure 55psi and holding Temp crept up to 205 after about 15 mins at 2500 rpms. I shut 'er down and I'll run it some more tomorrow. My engine, .030 over has the #15 heads, stock HEI with the RAIII cam and RA exhaust out to a set of Flowbies. I will be putting in the full PYPES Xpipe setup on this week. My question is how long and what RPM for proper cam breakin? I gleaned a ton of info regarding the exhaust and HEI setup off this board, many thanks to all contributors, it's like the PONTIAC library of congress with the loads of good info/pics regarding PONCHOS. ITO |
congrats man!
Congrats, got to love a newborn 455!! For cam break-in I run 2000 rpm's for 20 min. so I think your about done. Take it for a spin and enjoy!! I usually do an oil and filter change after about 50mi. everyone has there own break-in ritual. Have fun.
Cam is usually broken in with 20 mins. at 1800-2200rpm, then oil+filter change. After 100 or so miles change oil+filter again (vary rpms, nothing constant, to break in rings). Engine should free up and cool down after about 500 miles. Remember to use GM EOS and rotella 15-40 (or equivelent)for best cam and bearing protection.
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets. 1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram. |
Change the oil with either VR1 or Rotella. VR1 preferred. Add EOS and run it for another 15 mins @ 2000+ rpm. I would change it one more time and then drive it as Billit suggests for a couple hundred miles. I wouldn't baby it but no blast to the redline either for the first hundred miles or so.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi. |
Thanks everyone for the great suggestions. Secondly where do I a find Rotella and GM EOS? I figure the Rotella is in the dairy section at NAPA but I have no idea where to find the EOS. I presume it is an additive offered at the dealers service dept? The engine runs smooth and sounds great after 20-25 mins at 2K and I dropped a little knowledge off to my 13 year old son. He helped alot with the re-assembly and seemed genuinely interested. I overheard him bragging to his buds about it as well, so I think the flame is flickering. Hopefully he'll drive a classic Pontiac someday instead of an import with a goofy wing on the back. Thanks again for all the info, much appreciated. ITO
GM EngineOilSupplement from any GM dealer parts department and the shell rotella 15-40 diesel engine oil can be had at most auto parts stores.
