Fuel pump inlet?
I'm looking to put a fuel filter before my fuel pump.
Can anyone tell from the attached pic, which of the two SS braided lines is the inlet to the pump? Thanks!
1969 Pontiac Firebird |
The one on the right.
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
The one with the worst hose clamp job I've ever seen, haha! Going on 3 years now correcting small stuff from the previous owner, never seems to end.
Thanks a lot!
The one thats NOT going to the carb!LOL
Haha, good one. Shouldn't own a car if I couldn't figure that one out
Just as an FYI, it is not recommended to put a filter prior to a mech fuel pump, those things 'pull', and can effect flow.
Mech fuel pumps struggle as it is with a decent engine, adding a filter before the pump will make it worse. .
X2, do not place a fuel filter in between the tank and the pump if that's the only pump on the car!
If the motor still has the stock Q-jet on it then the long paper filter is fine up to about 400 hp with a pump like most stockers that output 6 psi. If your Carb is flooding out and your finding little black spec's holding the neddle open then it's time to replace all the rubber hose on the car as its breaking down.
How old is he braided line?
The one hanging lower on the left is IN.
High on the right is return. Solid line going up to the carb. Clay
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
The braided line is from 2015.
Sounds like I'll just leave the filter where it is before my carbs fuel rail. Thanks!
You know....I didnt look at it long enough! You are correct,
