Old 08-26-2002, 10:02 AM
A1Judge's Avatar
A1Judge A1Judge is offline
It just goes to show you, always get back to basics. For all of you that have helped me in the "surge" / "miss" problem I was chasing,,, I finally got the answer this weekend.
After trying multiple combinations of jetting I still had the miss. So I went back to basics, pulled the distributor and meticulously went through it. I found the points plate was worn and had a significant wobble to it. Enough that the dwell was probably fluctuating and the points inaccurate when it was running.
I pulled out the original distributor that came with the car, checked everything, cleaned it up, reassembled it with new points and condensor popped it in, set the dwell and timing...
I also made a slight adjustment to the choke and limited the travel so it didn't open to a 90 degree state when warm, maybe 75 degrees or so and presto! Runs like a charm, pulls strong and cruises like a brand new car.
Ended up with 073 jets and 041 rods, B secondary hanger and CE rods.
Put 80 miles on it yesterday, AND took second place in a POCI sponsered local all Pontiac show!
All in all a great weekend!
Don
My 70 Judge Restoration documented at: http://thejudge.dyndns-home.com:8080/
A1Judge's Avatar
Don
Old 08-28-2002, 02:57 AM
bob8748 bob8748 is offline
Runnin good and second place... Congrats!
So let me get this straight:
Your Honda has 1.6 liters and my bottle of Mountain Dew has 2?
Old 08-28-2002, 08:37 AM
A1Judge's Avatar
Thanks Bob
I still think there is something wrong... Shouldn't the primary choke plate be wide open when warm? Once I closed mine down it smoothed right out, vacume became rock steady at 11 inches and it gained about 100 RPM.
I am going to send the carb out to have it professionally done, probably in January. I can discuss the details with the shop. Maybe there is some junk restricting the gas flow at idle making it artificially lean...
Don
Old 08-28-2002, 09:55 AM
Calibrator Calibrator is offline
My guess is that you are lean for some reason. Vacuum leak?
