Old 06-10-2004, 07:35 AM
"Guy
Send a message via MSN to
My Heddman 1-3/4" came back from Moore coatings...sweet. I'm checking my exhaust gasket, felpro #1424 to the heads....the port size of this gasket is too big! Port size on #16's measures 1.75" high x 1.13" wide. Checked the gasket to my header and falls outside the machined weld sealing surfice.
What is the best exhaust flange gasket to use with #16 heads stock port opening heddman 1-3/4" headers?
Mr. Gasket #550?
"Guy
Mr. Gasket #550?
Old 06-10-2004, 08:19 AM
SCOTT ESTERLE's Avatar
SCOTT ESTERLE SCOTT ESTERLE is offline
I've used the Fel-pro's with D's & 1&3/4 Hedman headers with no problems.
Old 06-10-2004, 09:33 PM
mikeb mikeb is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Scott Esterle:
I've used the Fel-pro's with D's & 1&3/4 Hedman headers with no problems. <HR></BLOCKQUOTE>
Same gasket & header here too on some #62 d ports. No issues, no leaks.
Old 06-11-2004, 05:40 AM
"Guy
Scott,
Why did they make the port size bigger on the gasket than the port size on the head?
Seams to me it leak like a seive. Anyone else shed some light on this?
Old 06-11-2004, 07:11 AM
Here's a couple of pics of a 1424 sitting on an old #62 D port I have laying around in the garage. Does your's look like this?
I have another set of #62s on my bird with the same hedman header and they don't leak. Maybe you got some different kind of gasket(?)
pic 1
pic 2
Old 06-11-2004, 09:13 AM
"Guy
MikeB...
Yes they look like your pics. Over sized for the port. Mr Gaskets are closer to the port size, What gives why wouldn't Felpro make a gasket that matches the port size?
Old 06-11-2004, 09:17 AM
wheelspin's Avatar
Porting allowance?
Les
Les Iden
Old 06-11-2004, 10:13 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Wheelspin:
Porting allowance?
Les <HR></BLOCKQUOTE>
That's my guess also
Old 06-11-2004, 10:14 AM
6567GTO's Avatar
6567GTO 6567GTO is offline
I installed a set this week and like the fact that they're a little larger. There's no chance that the gasket will block any of the exhaust flow. With casting irregularities it makes more sense to open up the holes a little.
_________________________
Sonny Barger
