Old 05-04-2023, 11:45 PM
GILLIGAN GILLIGAN is offline
Default RAM AIR V compression ??
lost again poo poo
factory block/crank/rods/heads
all 400
diamond 4.155
comp height 1.720
eff.volume +13.5 ccdome
int pocket 0.140
exh pocket 0.175
deck and milling head unknown
? gasket thickness to get about 11.1 ?
john ricondas V
thank you folks
Old 05-05-2023, 06:10 AM
Here's the only answer that anyone can give you without YOU providing the rest of the needed details.
With a piston at TDC you need a total of 83.3 CCs to achieve a 11 to 1 compression ratio.
The other thing that's certain is that 13.5 cc dome needs to go since I don't think you be wanting to grind / machine that 13.5 CCs into the chamber even if it could be done.
Old 05-05-2023, 10:17 AM
tom s tom s is online now
Might give Rick Johnson in Crete IL a call and see if he remembers what the CR was.Custom Automotive.Make sure you have some time to give up when you call!Tom
Old 05-06-2023, 03:05 AM
Default thanks STEVE !!!
thank you steve your darn smarter than me
Old 05-06-2023, 03:08 AM
Default thank ya TOM
fishin must be good for memory
now i remember to have AMPLE phone time/that is a great man that helps us
