Old 03-18-2002, 01:23 AM
Jason H Jason H is offline
Is there any gain to blocking the exhaust crossover on the manifold? If so whats the best way to go about it? I was just wondering if it would be worth the trouble.
Jason
Jason
Old 03-18-2002, 02:22 AM
Bart Bart is offline
The best way to do it is to fill the heads with molten aluminum from junk pistons. It is more beneficial to fill the heads instead of the intake. There are several posts that discuss this in detail. Just search for "head filling" or "exhaust crossover" and you should find everything you need to know.
"I don't make the same mistake twice. I just keep making new ones!"
Old 03-18-2002, 04:24 AM
Bud Lyons's Avatar
Bud Lyons Bud Lyons is offline
Send a message via MSN to Bud Lyons
Jason, if you fill your head you will have to clean out your exhaust port due to Alum. flowing into it. By filling your head the exhaust gasses don't tumble around the cross over.
1/2" Stud has a real good explination of this. You can Email him for more info.
WWW.PatriotGuard.org
Standing for those that stood for us.
Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I.
One for your soul; the other for your freedom
Old 03-18-2002, 10:48 AM
Tim Swain Tim Swain is offline
Filling the head is the best way but you can block it with the tin piece you get from MR Gasket intake gaskets and I think Felpro has a block out now too. I've used this method for years but next time my heads come off I'm gonna fill'm.
Old 03-18-2002, 11:08 AM
Thanks for the answers. I plan on running nitrous. And from what I read on other post, the center 4 ports will not be working as well as the outer 4. Only if you block it between the head and intake (if you fill in the head I didn't see any problems). I didnt want to create a problem and possibly blow sometime up. So I think I'll just leave it alone.
Jason
Old 03-19-2002, 03:30 PM
Half-Inch Stud's Avatar
Ahem,
Blocking the Y-crossover within the Pontiac head is key to avoid cross-contaminations of Cyl 6 Exhaust pulse into Cyl#4 Intake pull. Also Cyl 5 Exhaust pulse into Cyl#3 intake pull. Idle quality will clean up too.
These comtaminations are often mistaken for Reversion. Tell-tale signs are carbon streaks in the Intake runners. Significant with high duration-overlap cams.
Molten aluminum remains the easiest plugging method. I plan to plug 4 heads soon.
H.I. Stud...........Mark
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
