Front end limiter installation
Does anybody have a picture of how they have there limiters installed on a abody?
A new best of 9.135 @ 145.41 71 Lemans Sport. 72 Lemans Sport. |
limiter
This is how mine is.
68 Lemans 505 cu in 9.892@136.18 69 FB 455 cu in 11.97 |
Do u have stock A Arms?
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
What kind of rear suspension setup?
Stock front control arms. The rears are edelbrock uppers and lowers with strange double adjustable shocks.
He is having a problem with wheelies, not knocking the tires off the car.
I just measure from the center of the center cap on the rim to the bottom of the fender when u jack the car up in the front crossmember. Just measure the turns u put on the limiters and make it the same for both sides and that will get you in the ballpark.
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Front shocks are Viking double adjustable.
Go max on extension doesn't help! ?
He has a car that makes power not a slow azz dragster that wouldn't pull the from tires if you sprayed it.
My slow dragster pulls the wheels, how does the shock thing work for that? Tell him how much travel he has with the wheels in the air, whether 10" or 3 feet off the ground? When you learn to scale your chassis maybe you can tell him how to do his?
Correct!
It's piontless to argue with him.
The shock that was one the car in the video were calvert 90/10
1/2-13 stainless nut TIG welded to the A-arm, 1/2-13 stainless bolt with a large flat washer welded to the head of the bolt so the rubber bumper has something flat to bump against. I cut a screwdriver slot in the end of the bolt so you can make adjustments from the top, another 1/2-13 nut locks the adjustment.
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
