Starter Bolt Size
I need to get a couple starter motor bolts... parts store has several GM sizes. Anyone know what size I need? '75 455.
thx. |
The Following User Says Thank You to TheMonkey For This Useful Post: | ||
4-1/2" long (roughly)
Same as the "long" Chevy bolts. The knurls will stick out the top of the starter nose and locate in c'bores in the block. |
The Following User Says Thank You to RobbMc For This Useful Post: | ||
Starter Bolts...
Monkey, the stock Pontiac starter bolts are 3/8-16 x 4-3/4" in length and are knurled on the ends, this length is for the stock delco starter.
If this is the starter you are using why not buy the correct bolts from PY or Ames. PY part number #GME-134 Ames part number #FN-403S Ames part number for starter shims #FN-404 Some of the mini starters on the market may use different length bolts but they should be included with the starter. How did the lower dipstick tubes i sent you work out for you?
"Three may keep a secret, if two are dead" ~ Benjamin Franklin ~ |
The Following User Says Thank You to Robert Williams For This Useful Post: | ||
I have the RobbMc mini starter that uses stock bolts. Local shop has GM starter bolts that are 4 5/8. Sounds like those are the ones.
Thanks again. Scott. |
No, don't want anything back, keep it or give it to the next guy, i have a box full of them. Glad everything worked out for you and good luck with the build. If you need anything else just let me know and i will try to help you out.
