Allpontiac Tiger Cub pump gas 505 696HP
Allpontiac Tiger cub 505 punp gas ,10.3 cr hyd roller AP fits under hood manifold ,AED 1000HP carb ,HEI .Engine kit shipped to Australia assembled and dyno in AU.Engine made 696HP at 6000rpms and 681 torque at 4900rpms.CFM cnc ported Edelbrock RPM std rocker location ,Race Tech pistons cam BCCE-AP 242-251-112 .650-630 with AP Tiger Cub 1.7 rockers .Bill C.
Checkered Flag Machine & Ceralli Competition Engines Racing engines and induction development http://www.checkeredflagmachine.net/ |
Good Job, Engine makes about 50 more HP vs the typical Standard Port E-head with a .650 lift camshaft and similar duration at a lower rpm with a Hydraulic Camshaft. SWEET!
Very nice!! Especially with 10.3 compression. Care to expand on the "AP fits under hood manifold"? Hyd roller? Solid or Hyd lifters?
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/272@.050 Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight. |
Congrats Bill!
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
Nice Bill. Congrats to you and crew.
Thats a nasty powerplant. Is the kit purchased through you Bill or All Pontiac?
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
Now that's a pump gas combo.
What are the torque numbers? john |
Allpontiac 505 Tiger cub
Purchase through Allpontiac as kit or assembled.Torque was 681Ft Lbs at 4900 rpms.Cam was for the intended power curve ,Would use different lobes for different applications.Bill C.
oops...I didn't see the tque listed in the first post.
Would that cam be happy at 2000 rpm in overdrive? |
What intake? Shaved down Victor?
Nice lil street build bill .
What's ballpark pricing on a set o tiger cubs?
Price of a set of Heads ready to bolt on with the Best Springs and Valves.
$3295.00 Complete.
Bob C. Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads Boss Bird Funny Car Best pass to date 08/06/2016 6.027@231.64 Allpontiac Big Chief Aluminum Engine Block http://www.AllPontiac.com |
This includes Titanium retainers ,10 degree valve locks,spring locators,andHyd,roller springs good to .700 net lift.Bill C.
Another high quality head option.
Thank you. |
how much if I supply the heads?
Thanks! |
No info on the intake used?
Awesome deal Bill!
Congrats on the success.
DOC'S TA Turbo 535, CV 1 heads. Built by Cerralli Competition Engines Tenth Anniversary (Van Nuys) restored. Tenth Anniversary Barn Find (Norwood) Both 4 speeds! |
