Old 07-29-2023, 11:03 PM
Shiny Shiny is offline
Default Going Mobile!
I just drove the beater around the block for the first time since ~2008! I am smiling big.
Can't thank you enough for helping me get to this milestone. You all matter!
Woo hoo isn't even close!
Here's the maiden voyage out of the garage:
https://1drv.ms/v/s!AiIRc33Ia4jVi7oO...wu7rQ?e=R0iRn6
My wife says I need to go get groceries!
Mike
The Following 4 Users Say Thank You to Shiny For This Useful Post:
Old 07-29-2023, 11:51 PM
Congrats 15 years is a pretty long slumber!
Old 07-30-2023, 02:09 AM
locomotivebreath's Avatar
locomotivebreath locomotivebreath is online now
That’s cool ! Why so long ?
When I wore a younger man's clothes
Old 07-30-2023, 07:45 AM
1968GTO421's Avatar
Congrats! Long time but life does present obstacles to us and our Pontiac's unfortunately.
GTOAA--https://www.gtoaa.org/
Old 07-30-2023, 11:35 AM
shaker455's Avatar
shaker455 shaker455 is offline
Mike
Congrats Mike and glad to have been part of your project!
I pulled out my 70' Camaro after a 34 year sleep and back into service.
So I understand
Carburetor building & modification services
Servicing the Pontiac community over 20 years
Old 07-30-2023, 01:03 PM
Thank you
Yes, life happened a lot, I made mistakes, the car kicked my butt many times, and I lost motivation more than once.
Long story nobody wants to hear but the history is probably well-documented on this forum. As I said, I would have tossed it 15 years ago if not for the support I get here.
Breakthrough was stepping up to the carb and distributor this year. Jeff (Shaker455) and Bob Davis (Sun Tuned) rescued me on both, with lots of help from others.
I had started on body work 15 years ago so had the front clip apart and moved the car twice in pieces. I retired and moved here 4 years ago. The car sat here while we turned 5 acres of weeds and a big house into a nice place. We are now downsizing and moving again so I set a goal to move the car in one piece. No more inner fenders, bumpers, and headers in the shed! I'm close..
Turning it into a driver while continuing the body work is finally within reach.
As it rolls (some of the projects I DID get done in 19 years with help from the forum):
Mechanical
  • Rebuilt rear axle, added Eaton posi, new 3.55 gears, new u-joints
  • Rebuilt/restored suspension, boxed rear arms, added sway bar, new springs, new rag joint
  • Original 350/heads and TH350, Summit 2800, Q-Jet, replaced timing cover, new water pump, new harmonic balancer
  • New brakes, conversion to power front discs
  • Rebuilt/installed Jeep steering gear, rebuilt steering pump, new tie rod ends
  • New gas tank, fuel pump
  • New radiator, new heater core
  • Convert to single-wire alternator
Body
  • Restored firewall, AC box, fan shroud, and fan, new fan clutch
  • DS fender patch panel, welded holes (was a Sport fender)
  • Replaced/restored radiator support
  • Repaired header panel
Interior
  • Swapped bench for buckets, new covers
  • Capped dash pad
  • Rebuilt instrument panel, restored bezel
  • Repaired and installed dash tach, AM/FM Stereo radio
  • Restored AC/heater controls
  • Restored and installed floor-shift column, changed to Formula steering wheel
  • Added courtesy lights
  • Restored and installed console
  • Installed floor shifter
I've still got a list to get it driving, another list to finish interior, and a daunting cosmetic challenge but I'm really happy to have it moving under its own power.
Thanks again to all!
Mike
The Following 3 Users Say Thank You to Shiny For This Useful Post:
Old 07-30-2023, 01:10 PM
Thank you. Yes, yes it is!
Thank you. Ha! I just posted the "short" version.
Thank you. Lots of lessons from both.
So I understand
Thank you Jeff. You are high on my gratitude list. Not only did you give me hope for fixing a Frankencarb, your generosity and skill turned the hope into reality. I hadn't started it in the months since you fixed the carb. I poured an ounce of fuel in it yesterday, hit the starter, and it fired instantly.
Mike
Old 07-30-2023, 02:14 PM
67drake's Avatar
67drake 67drake is offline
Congratulations!
My car hobby goes in cycles. Sometimes, like lately, I am doing a whole list of projects.
I bought a ‘63 LeMans last year that is a great solid driver. Unfortunately, the previous owner had a different standard of a car that was “ready to drive cross country”, I could barley drive across town with it.
My ‘71 was boxed in my pole barn at my old house. So when I moved there 5 years ago it pretty much sat, as I bought and renovated a handful of rental properties.
Now that things are settling down, and I bought a house with a great 30x40 shop-I’m back!
13.95 @ 102.1 on street tires @ 4055lbs.
The Following 2 Users Say Thank You to 67drake For This Useful Post:
Old 07-30-2023, 06:25 PM
shaker455's Avatar
Mike
Your very welcome! Glad I gave you that boost!
The Following User Says Thank You to shaker455 For This Useful Post:
Old 07-30-2023, 09:46 PM
Verdoro 68's Avatar
Congrats! Nice to see so many cars on the move around here recently.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
Old 07-31-2023, 06:06 AM
JSchmitz's Avatar
JSchmitz JSchmitz is online now
Great feeling I'm sure! Congrats!
The Following User Says Thank You to JSchmitz For This Useful Post:
Old 07-31-2023, 06:36 AM
dataway's Avatar
dataway dataway is offline
Sounds good, no smoke, moves forward and backward .... means you are 90% there far as I'm concerned
In my mind I often used the phrase "moving under its own power" as the biggest milestone to completion ... and there you are!
Old 07-31-2023, 10:06 AM
Thank you!
Yes, yes it is, thank you!
And it stops, so I'm going to call it 91%! The brakes were part of what busted my butt many years ago. Thanks for your help getting here - like the distributor do-over. I am going to review your recent discussion about coarse wheel alignment as that's on my list soon.
Mike
Old 07-31-2023, 03:43 PM
amazing...congrats on a long haul
Old 07-31-2023, 05:21 PM
blueghoast's Avatar
And it looks so clean body wise?
GT
