Old 07-10-2023, 09:26 AM
Shiny Shiny is offline
Default Wire Routing Clips?
It's awesome Ames has these but it adds up fast for 6 of them.
Anyone know of a less expensive (ie parts store) functional equivalent?
Mike
Old 07-10-2023, 10:57 AM
Trevor78 Trevor78 is offline
Got a pic?
Old 07-10-2023, 11:08 AM
Woops, sorry about that... I uploaded last night and today they are gone because I hadn't submitted the post. Noted.
Name:	Ames J Clip.jpg
ID:	615715   Click image for larger version
Name:	Wiring Harness Clip.jpg
Old 07-10-2023, 11:26 AM
Stuart's Avatar
Stuart Stuart is offline
You could check if https://www.clipsandfasteners.com has something that would work.
The Following User Says Thank You to Stuart For This Useful Post:
Old 07-10-2023, 02:08 PM
Thanks Stuart
They have these that are inexpensive and might work. I'll have to check clearance above the clip mounting hole:
It also appears late sixties Mustangs had something similar and are likely to cost less than Pontiac parts. AMK has at least one version but they want $30 minimum and shipping costs are significant.
I'll try to find something like these at a local parts store.
Mike
Name:	Clips and Fasteners Half Inch .jpg
ID:	615727   Click image for larger version
Name:	67 Mustang Clip .jpg
Old 07-10-2023, 09:13 PM
BB70's Avatar
BB70 BB70 is offline
Zip ties with christmas tree molded on. Probably find similar at the parts store.
The Following 2 Users Say Thank You to BB70 For This Useful Post:
Old 07-10-2023, 09:19 PM
Stuart's Avatar
You could also try some of the weatherstrip manufacturers, like Steele Rubber or Metro Moulded Parts - I believe they carry a number of universal style clips as well.
Old 07-10-2023, 09:49 PM
Thanks for the ideas!
I ran into O'Reilly's and they had nothing in stock nor easy for them to find. I will look at their web site as they can get stuff very fast and don't charge me shipping.
The zip-tie with a tree deal looks easy and cheap. Both good things so I'll look for those.
I can get the round one through eBay for a reasonable price too. It is an Auveco part #14531 (1/2") or 14533 (3/4"). I have to look at clearance above the holes in the radiator support before I go for this option.
I'm still trying to find prices and options for those 67 Mustang clips. They are really close to the Pontiac parts.
Old 07-10-2023, 11:12 PM
bdk1976 bdk1976 is offline
I used black zip ties on mine - not the prettiest, but not really noticeable either.
The Following User Says Thank You to bdk1976 For This Useful Post:
Old 07-11-2023, 10:48 AM
Thanks to you both. Turns out these are in stock at O'Reilly's:
I found a used hood release rod at Desert Valley Auto. I'll ask if they also have the "correct" clips used. If not, I'll go with these push-ties!
Great to have your help.
Mike
Old 07-11-2023, 12:34 PM
This:
Name:	Dorman Push-Tie.jpg
Old 07-12-2023, 06:10 PM
The push-in clips worked fine. Thanks again for the ideas.
I actually had 2 originals still intact but they don't hold the wire any better than the zip-ties.
Onward
Mike
