Cam thrust plate
i cant stand it anymore. ive searched and searched but cannot find.
who makes the cam plate with the oil groove around the outside? thought it was TIP, but no. And i was just on that vendors website like a week ago. i hate, really hate, being adhd.
costs too much |
"Three may keep a secret, if two are dead" ~ Benjamin Franklin ~ Last edited by Robert Williams; 08-08-2008 at 06:28 PM. |
I would avoid the grooved thrust plate like the plague. The thrust plate gets a metered supply of pressurised oil PLUS it gets oil splash/drip from the rotating sprocket PLUS it gets lubed from pressurised oil exiting the front cam bearing. Lubrication is not the problem. The stock plates often have a 'step' in them from wear. That tells a story, but not a lubrication story. The story is that there is insufficient surface area for the load. Grooving the thrust plate only reduces the available area, when what is needed is more area.
The Following User Says Thank You to Geoff For This Useful Post: | ||
Ditto. If ya got the bucks. The rollerized unit is the way to go. On all my Hi perfromance BBC & SBC's with double rollers, I uses the torrington bearing timing sets with cam buttons. I don't know how many BBC's I have seen or had to have repaired from grooved timing sets for so called better lube, acting like cutters and cut into the block as it rotated. If you could run an engine without a timing set you would see the cam either try and walk out the front or back of the block. |
Have a machinist friend cut a small groove on the stock plate,there is sufficient surface area, it only cost the price of a Happy meal.
http://forums.maxperformanceinc.com/...m+thrust+plate
Read that thread, you will like what you see. I know I will be using one of Sims Performance Machining thrust plates in my next build.
1971 Trans Am - Sold 1977 Can Am - Sold 2002 Trans Am Firehawk - Sold 2004 GTO - Sold 2006 GTO - Sold 1970 GTO - Sold 1972 Trans Am - Sold 1970 Trans Am - Current Project |
I use the grooved thrust plate from Nitemare Performance. It is grooved only between the plate and the #1 cam journal. It is flat between the thrust plate and the cam gear.
I also use the bronze thrust washer style timing set. I polish all working surfaces to a mirrior finish...Robert |
The way I see it, the cam thrust plate problem is due to the same reason[s] that the #4 crank thrust bearing fails: everything works well, until the engine starts getting modified for more hp.
In the case of the cam thrust, heavier oil &/or a stronger oil pressure spring puts more load on the thust plate. As with the crank thrust, more area is needed to spread the load, NOT more oil. The cam is easier to fix than the crank, & I am surprised it has not been done. Maybe the failure rate is not high enough, or it is not a big enough problem?? Maybe someone will make a new thrust plate that has a smaller centre hole, so it just fits over the cam nose; this would substantially increase the surface bearing area, using the FULL surface area of the front cam journal. The lip on the rear of the cam sprocket would have to me machined off, so maybe the product would be sold as a 'cam plate & timing chain update kit'!?? |
I just realised my suggestion in post #9 won't work! The fore/aft cam movement has to be limited.
Maybe the lip on the cam sprocket can be reduced in OD, & the hole in the thrust plate correspondingly enlarged to increase the bearing area. |
Just get the Simms cam bearing/retainer and forget it !!
No more cam walk and dyno showed HP increase... Just do a search on it here..
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
i was under the impression the sims deal was part of a package that included the timing chain. is not? i have, two actually, cloyes true roller sets, so i'm not too inclined on getting a third.
costs too much |
It is the whole set with instuctions and alignment tool.
1964 Tempest 9.73 @ 136.9, 525, Kaufman D-Ports, Pump Gas 3670 W/Driver. In the 9's on pump gas! |
Contact Scott @ simsb52@qmix.net to get pics, instructions and questions answered.
My vote goes to Simms as well. |
