#41
It’s really up to the individual if they want to put that kind of money into a stock block with no caps. It also depends on what the intended use is going to be. The scary part is seeing what 64speed just went through with the pin hole. Can you imagine if it was one were they had to put/fine caps for it or bite the bullet and go steel caps. The good thing about this thread is to make guys think of the possibilities after investing that kind of money. Hopefully it helps them to make the right decision. Rather then have guys encourage them
The Following User Says Thank You to Gach For This Useful Post: | ||
#42
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell Last edited by hurryinhoosier62; 05-03-2023 at 02:52 AM. |
The Following User Says Thank You to hurryinhoosier62 For This Useful Post: | ||
#43
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
#44
Mine I tried to sell it for 1500$, a steal really. I was not going to give it away so I just finished the engine that originally was to be a 650 HP type build but has been tweaked up a bit to 700 HP or thereabouts. Sentimental reasons too. Dan Whitmore was the person who taught me the most about Pontiacs and its the last block he ever did. I got it back after he passed away. The cap fitting line bore hone was finished by him and checked out to be dead nuts on by a local machinist. I paid for the bore and deck job twice because he passed away but thats how it went. At least I know I have a good one because his name was on it. He would not waste his time and customers money building a suspect block. It was one of his personal blocks he tucked away under his bench years ago and only sold it to me after I had trouble finding a good block. I had a std bore 4 bolt WS block out of a 70 Judge with all the main caps. But I was not going to build it to race and beat on. It should be for a Judge resto and I sold it for that. Got 2200 $ for it. BTW, what does NDT stand for ? |
#45
Some of the best Pontiac engine builders have experienced this.
#46
So you’re just assuming he sonic tested it.
Don't put words in my mouth.
#48
So way back in the early 2000s when I asked him if the bores were checked and all he said yes. Dan Whitmore telling me that was good enough for me and there was no reason to have him sonic check it again just so I could have the sheet. He knew if I was going to do this I needed to have a std bore block I could re bore down the road. This was discussed and key to the whole deal.. WE were friends and Dan was more aware of potential problems than just about everyone alive. He was very thorough and his reputation was as good as it got. He was so anal about this stuff when he filled the block he had a torque plate bolted down to each deck while curing for several months, each side. If you knew him there was no way he is putting in all that work unless the block is good. |
#49
Oh I knew Dan very well, definitely one of the best, as far as I know he didn’t have sonic tester he use to send blocks out, and would give you a copy of the sonic test. Only because your talking a good $2500.00 investment for the right sonic test equipment. Just surprised you didn’t get a copy of yours.
PS: thats why I said you’re assuming that it was done.
#52
#53
If that is the case you are good. Stan
The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
#54
He could not bore it with a tq plate so he bored it .010 under than honed the rest with tq plate. |
#55
Gotcha
OK if someone made us a block something like a 70 RAV block but with a sbc style valley area, 1/8" more meat around the lifer bores, siamessed cylinders, extra rib on the pan rail like 59-60 blocks and ductile iron splayed main caps and thick main webs like a IA2. That should do it, hey I can dream with the best of them. Oh, about 2,500$ too. |
#57
And it came true for my family. Growing up we had a 66 Catalina Station Wagon and it finally died from a cracked cylinder. We junked it with nothing wrong with her but the engine. I just took the AFB carb and intake off it. Took it for granted as it would be cool to have now. Right now I am dealing with having to move one header tube, just kisses the kickout on the oil pan. I don't want to dent it and there is enough room to move it so I am sending back to the guy who made if for modification. I have too much time and money into them with the O2 bungs and merge collectors (expensive!) to have them look bad. Powder coating them inside and out. Last edited by Dragncar; 05-04-2023 at 01:06 AM. |
#58
The Following 2 Users Say Thank You to PAUL K For This Useful Post: | ||
#59
#60
