Old 05-07-2020, 07:04 AM
What is not correct on Post #39 Kenth?
You mentioned the Jets and I have posted the jet info again right from the build sheets:
(MM. Jets: 299 cc, 60 degree, 7008660 "B" )
I read the 7008660 as being a #60 main jet with a 60 degree entrance angle.
What other info on Post #39 are you saying is incorrect?
Bart removed the info on the original post #39 and replaced the info which I sent him later. Did you look at Post #39 again or assume that it was the old info?
  #102
Old 05-07-2020, 10:59 AM
Maybe he's wanting the 389 7026074 info?
  #103
Old 05-07-2020, 11:39 AM
SAME CARB CALIBRATION (PER ROCHESTER PRODUCTS) and tag number for both engines 389 and 421 in 1966. This is the center carb. There is no unique 421 carb vs 389 carb for the center location with that number.
Good question though.
  #104
Old 05-07-2020, 03:21 PM
Kenth's Avatar
Kenth Kenth is offline
Tom V, i went back to post #39 and there it was! I wasn´t aware it was edited.
Thanks for your info.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
  #105
Old 05-07-2020, 03:29 PM
Why was the post #41 different than post #39, when using the same carb#?
  #106
Old 05-07-2020, 04:39 PM
(notice the date change TV)
All you have to do is look at the whole document line by line.
  #107
Old 05-08-2020, 02:45 AM
Kenth's Avatar
Looks like carb in #41 posting is 7026075, not 7026074.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
  #108
Old 05-08-2020, 06:21 AM
The confusion is, Kenth, I was checking the info on post #39 each time and finding it all correct. each time. And you and John Wallace kept referring to 7026074 carb.
Post number #41 has one error I believe, the carb number should be 7026075
It has the 322cc 60 degree 7008662 "C" jets.
So you kept steering me down the wrong path.
Nothing wrong with 074s info in post #39
Post number #41 has the correct info for 7026075
and I will ask Bart to just change the model number from 7026074 to 7026075
One simple change. I agree with you Kenth. Wallace just confused things.
Bart, I will sent you a PM on this.
  #109
Old 05-24-2020, 04:16 PM
Very Nice to see that we have a Tri-Power Sticky in the Tri-Power Forum now.
Thanks Stuart and Bart.
I am going to try to fill in the 1965 Carb Info here for the 389 engines and the 421 engines. The 389 engine carb part numbers are:
Front Carb (389 engine with Automatic Trans) 7024178 (POST # 33)
Front Carb (389 engine with Manual Trans) 7025178 (POST # 52
Rear Carb (389 engine with Automatic Trans) 7024179 (Post # 34)
Rear Carb (389 engine with Manual Trans) 7025179 POST # 43
The Center Carbs are:
(389 engine with Automatic Trans) 7025173
(389 engine with Automatic Trans) 7025177
(389 engine with Manual Trans) 7025175
This is the only center carb offered for the 389 engine with Manual Trans in 1965
So we have SEVEN 1965 carb listings for the 389 engine.
In order to save on typing and possibly making mistakes on the same carb I will list the correct post number with the given carb information Example 7024178 posted previously is discussed in post # XXX
Time to do some searching of previously posted info.
  #110
Old 05-24-2020, 07:40 PM
DavesGTO's Avatar
DavesGTO DavesGTO is online now
Hope this is helpful, not sure if posted before.
Last edited by Stuart; 05-24-2020 at 10:14 PM. Reason: Images resized and reposted below.
  #111
Old 05-24-2020, 09:53 PM
Thanks for posting, I see that it lists the carb tag part numbers.
Rochester Products Engineering was kind enough to send me the actual build sheets for the different carb numbers you show in your book. So that just confirms that the info I have pretty much matches what they supplied to the parts organizations.
Thanks again. I now have one issue based on your post, the pages are so big that it is impossible to post the info in the format I was using prior to your post.
Maybe one of the Mods (Stuart or Bart can resize your post to get the sizing back where it was earlier today. I will send a PM to Stuart asking for help on this issue.
  #112
Old 05-24-2020, 10:13 PM
Stuart's Avatar
Stuart Stuart is offline
Repost of DavesGTO's 1967 Delco Rochester carburetor information. Click on each image to enlarge:
ID:	540933   Click image for larger version
ID:	540934   Click image for larger version
ID:	540935   Click image for larger version
  #113
Old 05-25-2020, 11:42 AM
Thank You Stuart and thanks DavesGTO for the info.
  #114
Old 03-26-2022, 01:35 PM
Kenth's Avatar
Thank you Tom V for your postings in this topic!
I would like to add the applications on 1965 389 A/T center carbs:
(389 engine with Automatic Trans) 7025173, used on B-body cars.
(389 engine with Automatic Trans) 7025177, used on GTO´s.
Only differences are the Pump Shaft and Lever Assembly, #7017442 on 173 and #7015108 on 177 and the Vacuum Switch, #7028797 on 173 and #7029693 on 177.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
