Old 05-09-2018, 07:38 PM
Paulryder Paulryder is offline
Default Removing the engine from my 1966 GTO...Does the front end have to come off???
I am removing the 389 from my 66 GTO and I just discovered that my 1 ton engine hoist won't reach to middle of the engine when extended all the way. Do I have to remove the front end to get far enough in to get it out? Would a 2 ton hoist have a longer reach?
Old 05-09-2018, 08:19 PM
goatmanmitch's Avatar
goatmanmitch goatmanmitch is offline
I have a 2 ton hoist and it needs to be extended as far out as it goes to reach the middle of the engine, and there is only an inch or so between between the hoist and the front bumper.
ID:	482654   Click image for larger version
Mitch Kunath
Old 05-09-2018, 08:33 PM
How about from the side? Lift it up then push the (much lighter) car back out of the way, then let it down.
Old 05-09-2018, 09:02 PM
Buy or borrow a 2-ton hoist with a boom long enough to do the job. Mine barely clears the front bumper as well.
Pulling all the front sheet metal off the car is totally unnecessary and just creates an adjustment nightmare.
Old 05-09-2018, 11:14 PM
I think you're right on the mark. I looked things over and I don't want to pull the front off. Thanks.
Old 05-09-2018, 11:15 PM
Thanks for pictures and info. I just found a Harbor Freight 2 ton hoist on Craigslist that I'll go check out tomorrow.
Old 05-09-2018, 11:17 PM
Good suggestion but the hoist still comes up short. Thanks.
Old 05-10-2018, 05:36 PM
GT182's Avatar
GT182 GT182 is offline
Make sure you remove the hood first Paul.
Doing from the side works. With the hood out of the way you can roll the engine stand back and clear the car... if you have enough room in the garage.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 05-10-2018, 06:34 PM
geeteeohguy's Avatar
When I pulled the engine on my '67 in 2011 for a re-seal job, I didn't even remove the hood. But I used a 2 ton hoist that gave me a lot of range of motion.
Jeff
Old 05-10-2018, 09:34 PM
GT182's Avatar
The "leveler" comes in handy too for the angles needed to get it out without damaging anything.
Gary
Old 05-11-2018, 12:24 AM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
You don't need to remove the hood on a '66. With a helper holding the hood up, remove the front 2 bolts of the hinges where they bolt to the fenders and loosen the rear ones and then swing the hood up until the rear corners rest on the upper cowl section of the body next to the cowl grille. Before tilting the hood back put cardboard at the corners of the hood to keep from scratching the paint . Then use a nylon strap or rope to hold the hood up by tying it to the rear bumper.
The hood will go about perfectly vertical when it bottoms out. It's completely out of the way for pulling the engine. I've done this several times and so much easier than removing the hood.
Old 05-11-2018, 08:43 AM
400 4spd.'s Avatar
And if you don't have a rear bumper, a tree limb will do.
Old 05-11-2018, 08:56 AM
thepontiacman's Avatar
My friend bought a long steel rectangular tubing and drilled holes in it to use with his engine hoist. It is adjustable for different front ends, as he works on many different vehicles. The end has a chain and hook just like the regular bar that came with it.
Hope this helps
Old 05-11-2018, 09:30 AM
400 4spd.'s Avatar
Thumbs up
Hope this helps
We should add that the wheels have to be extended longer than the arm reach also, to avoid tipping.
Old 05-11-2018, 10:24 AM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
Simple to do with the hood off. Can be done with hood on, but not tough to re align hood when reinstalling and with hood out of the way much easier getting to the back of the engine. However on this project I was converting to EFI and do a bunch of wiring and work on the back of the engine to hide it all.
ID:	482759   Click image for larger version
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
Old 05-11-2018, 07:34 PM
You can always have a friend stand on the back of the engine hoist to avoid tipping. ha ha.
We just had a extension long enough to do the job. Never had a problem with tipping.
Good Luck with your project.
