Old 12-29-2020, 03:52 PM
allenga allenga is offline
Default Borgeson Street & Performance Series, 12.7:1 Ratio - It's Perfect
Just thought I would share. I bought a Lares 1105 steering box to replace the original box to my car, and it was horrible. I could turn the wheel from center two-three inches each direction and the car would not respond. Also, the power assist was very low I assume due to the incorrect torsion bar size. I hated driving the car after this.
I then installed the Borgeson and its awesome. Correct power assist is back. No dead zone on center. Used their brass flare inserts for the hose connections. Instructions say to tap brass flare adapters in with a punch but mine fell in. No punch needed. One of the mounting holes has a clearance issue when using the stock frame bolts. The end of the bolt will hit the steering box body after you torque it down. You can Dremel it shorter, but I just used 3 washers. Borgeson says to use their rag joint but I preferred a factory style rag joint and got one from Lee Power Steering.
Spend the extra money and get a Borgeson.
The Following User Says Thank You to allenga For This Useful Post:
Old 12-29-2020, 05:09 PM
vertigto's Avatar
vertigto vertigto is offline
Good to hear. Looking forward to hooking mine up.
Old 12-29-2020, 06:04 PM
Half-Inch Stud's Avatar
Good to know. I felt that way going from a 1968 4-turn lock to lock to 69-70 2.8 turn Variable ratio box. done that a couple times.
Old 12-30-2020, 07:39 PM
64speed's Avatar
64speed 64speed is offline
Find my post on this. My car isn’t on the road but after exhaustive research this was the conclusion I came too. I hope my experience is a good as yours
Old 12-31-2020, 12:44 AM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
Part number? Purchased from?
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 12-31-2020, 01:31 AM
Brian Baker's Avatar
I don't follow around here as much as I used to, so I'm asking...what car did you put this in?
Old 12-31-2020, 09:28 AM
Jegs. Part # 800130
Old 12-31-2020, 01:23 PM
Colin70TA Colin70TA is offline
Glad it worked out! They have been fantastic for our cars, quite a difference over stock!
Sent from my SM-A530W using Tapatalk
1970 Trans Am, numbers matching, White, Auto, A/C, Owned since I was 15.
1973 Trans Am, numbers matching, Brewster Green, Saddle interior...Sold :-(
1978 Trans Am 400-4spd, non-numbers matching 400, Low compression daily driver, 9.66@73.5mph 1/8 mile....Sold :-(
Old 12-31-2020, 03:15 PM
1968GTO421's Avatar
Interestingly Borgeson must require vendors like Jegs and Summit, etc., to sell the # 800130 for the same price-$445.50 FWIW
Still, I'm planning to get one for mine.
GTOAA--https://www.gtoaa.org/
Old 12-31-2020, 03:21 PM
I just can't say enough good things about the Borgeson after that Lares 1105. One thing I learned, if you have a good core and it just leaks (like mine), don't give it up.
