Accelerator cable direct replacement
Accelerator cable snapped at the gas pedal this weekend (that was fun).
I tried to find a direct replacement on line to match up to what I have, but the on I ordered doesn't match at all. (See OER part #9792222 attached photo) but I missed the fine print for 2V only. Different type of mounting tabs and not quite the same length. I since found that Ames lists specific 68 4v part ( FN377). Does anyone have experience with this one? Is it a drop in replacement or do I just need to get a generic cable, re-use the old sleeve and cut to fit? Also, not clear from catalog photos is it should be FN377 or FN377F?? Last edited by 68FB400; 08-31-2017 at 10:24 PM. |
The part you got looks like mine, 1969 Firebird 4bbl.
- Mike '69 Firebird 400 - Goldenrod Yellow, 455 +.060, '6s-7' heads, Comp Cam 276AH-10 (51-309-4), TH400, Ford 9-inch w/3.08, 800cfm Q-jet, Stock Intake, Hooker Headers, Flowmasters '68 Coronet 500 Convertible - Medium Gold Metallic, stock 318 +100,000 miles |
Ames Catalog page
That bracket looks like a 1972 and up A body one to me. I would use the Ames 68-69 F body 4 barrel cable and buy the correct 1968 bracket if it was my choice.
A Schab; You were right on the money.
Called Ames and went over their catalog with tech support. My bracket is a '72 as you pointed out. My cable sleeve wasn't correct either. Ordered up the right cable and bracket. Should get back on the road in no time. Thank you! Wayne |
Can you post up pics of the results? I've been drawing a blank on where to mount a kickdown cable bracket on my 68, due to the throttle cable design. Everyone with a 2nd gen gets to run down to any parts store, buy a $10 chrome universal bracket, and be on the road in 10 mins! I just can't see how to make something work...
1968 Firebird - 350 w/bolt ons, powerglide, 8.2 w/2.56's...whoppie! 1969 Firebird convertible - Dad's bone stock cruiser |
What transmission are you using ? The 2 speed auto and th 400 use an electrical kickdown switch.If you happen to have a th 350 you will need the 1969 F-4 bracket that has the provision for the cable and the correct cable.
Yes, the TH350 equipped cars use a bracket that accepts a plastic clip on the kickdown CABLE. It has a square opening that the clip snaps into and this bracket mounts near the rear driver side of the intake and carb.,
The TH-400 ONLY has the mount for the the throttle cable to get clamped into. Here's a pic of the TH350 bracket.
-- James Work '67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake." '75 Formula 400 - Daily Driver - Running with my Home Built 455 and TH400 Details here: http://forums.maxperformanceinc.com/...d.php?t=588372 |
That picture is for a second gen th 350. I thought we were dealing with a first gen.My mistake, sorry. The F4 bracket is one piece 1969 only part that has the square hole fore a 4 barrel with a th 350 cable.
My mistake.. Maybe we are talking 67-69... Here is a pic of one of those setups.
That last picture is not a 68/69 style. It most likely is mid to late 70's,maybe even early 80's 301.
Yes, you are right now that I look at it, it has an HEI.. I can't help at all...
I'll leave with this note. The main difference is - if the OP has a TH350, he needs the Square bracket for the plastic collar on the kickdown cable to snap into, as you described. right? Similar to the bracket in that pic above. If he has a TH400, he only needs, or only has now, the throttle cable bracket. I had one on my 75 Formula before I put the 455 th400 in it. I have it still. I tried modify it to work with the TH400 and it was not going to work. I'm out!
Wanted to provide an update:
I received and installed the 'correct' 68 throttle cable and 68 bracket from Ames.. See attached. Note: there is an existing aftermarket kick down switch. Everything mounted ok (now the coil bracket/nut is very tight behind the throttle bracket. In the photo the coil had not been mounted yet). The issue now is I do not get full opening of the carb with the gas pedal. It's coming up about 3/8" short of hitting the kick down switch so not quite full throttle. There seems to be a slight bit of play at the mounting point at the gas pedal. What are the recommendations for adjusting this and taking up the slack so as to get full travel/throttle? |
