Left front parking light lights but does not blink when turn signal is on?
Thanks!
1969 Judge (Liberty Blue / Blue, 4SPD) |
Thanks!
You've got a bulb out on that side or it's not grounding good. I think most of the time others will blink because they have a HD flasher installed.
So long, farewell. |
Lance, I don't know if that problem can be fixed, maybe I should take Red off your hands??? [img]/infopop/emoticons/icon_wink.gif[/img] LOL
-Matt P.S. I agree, with the grounds/bulbs idea.
____________________________________ "I work in high speed aluminum tubing." |
Check the socket on the lamp housing. This occurred on my 70 GTO and when I took the housing apart the socket was corroded and the ground was bad. PY sells a socket replacement kit for 6 bucks or so. Pretty easy to install, or you could buy the whole lamp housing for 60$.
I agree, bad ground at the bulb, burnt out bulb or corroded or rusted socket/housing. replacement would be my advice here.
Pete
