Old 10-14-2021, 02:42 AM
Chris-Austria Chris-Austria is offline
Originally Posted by ta man View Post
That is a mild lift compared to the real OF cam offered by SD. Butler doesn't call this the OF cam do they?
no, they don't
  #62
Old 10-14-2021, 03:00 AM
to be honest... I think the 236/242/114 cam from Butler is still not the biggest cam possible for a street driven 462cui... I'm a little surprised that idle quality is nearly as good as before with the 224/230/110 cam
I guess the next bigger Butler cam would work fine as well for the street: 242/248, .540/.563, 113LS
  #63
Old 10-14-2021, 03:33 AM
ta man ta man is offline
Oh for sure we are far from "the biggest cam possible" for a street driven 462 or similar.
I know I would like to upgrade again in the future...a little more duration and more compression.
With those Butler cams they are pretty mild for lift.Id sooner see more lift..my current cam is around a 660 lift with 1.65 rockers
  #64
Old 10-14-2021, 04:55 AM
Would I need better flowing heads, if I go with a high lift cam?
I have stock E-heads, no porting....
1.65 rockers would give me more valve lift and the new springs should be fine with a little more...
  #65
Old 10-14-2021, 01:06 PM
I'm not familiar with what the stock E heads flow but I'm sure they could take advantage of more lift. Your valve lift would go from .521 to .573 on the intake and the exhaust would go from .540 to .594. But then the issue you may run into is how close are you to coil bind with your valve springs?
All depends what your after for performance..some of us just try and wring out every last ounce of horsepower out of a combination.
  #66
Old 10-14-2021, 02:50 PM
coil bind height is 1.150, so I think max valve lift would be 0.60..
the problem is I don't want to remove the heads and I think the pushrods will not clear with 1.65 rockers?!
by the way... I think to remember that my heads flow somewhere between 260-270cfm
