Old 01-26-2009, 10:03 PM
steve's Avatar
steve steve is offline
Default QJET leak. whats wrong ?
it keeps getting worse. a few weeks ago the gasket was jut wet. now it it dripping ??
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-Moser rear-Dougs Headers....
Old 01-27-2009, 12:00 AM
shaker455's Avatar
shaker455 shaker455 is offline
Steve,
Your float level may be set too high or you may have the wrong airhorn gasket.
Old 01-27-2009, 01:21 AM
chiphead's Avatar
chiphead chiphead is offline
Yes, check the float height and airhorn screws. Worst case the airhorn may be a bit warped from overtightening. Cliff's kits come with a thick gasket that helps reduce the chance of leaking. However, if the airhorn is badly warped, you'll have to send it out for straightening.
Old 01-27-2009, 06:52 AM
RR67GTO's Avatar
RR67GTO RR67GTO is offline
It ain't flat that's why it leaks. Also, number 10 lock washers are a huge help.
Build it fast, build it right, hold On TIGHT !!!
Old 01-27-2009, 09:59 AM
67cruiser 67cruiser is offline
Try this please, always start with the 2 screws on the primary side under your choke flap,next to idle air bleeds. Loosen all you screws gently start with these 2 and tighten them first, next go to the next 2 towards back of carb. then tighten the front single one the the rmaining back ones. Believe me it makes a differance, By all means double check float level and if float is old replace it, it could be fuel soaked!
