Old 09-07-2018, 08:49 PM
You need 2 fuel tanks?
I would use a 'Y' fitting instead of the 'T' fitting.
On the filter, is it after the pump or before?
  #622
Old 09-07-2018, 09:03 PM
Glenn Lever's Avatar
Glenn Lever Glenn Lever is offline
More shots, close up, enhanced
Glenn R. Lever
Rochester, New York 14617-2012
Web Site http://www.leverfamilysite.com/
Front Engine Dragsters http://www.frontenginedragsters.org/forum/
  #623
Old 09-07-2018, 09:07 PM
The original tank was just over three gallons. We will redo the tank problem this winter. There is a "pill" in the fitting in the small tank to make sure both tanks empty at exactly the same time. Filter is after the pump
Glenn R. Lever
  #624
Old 09-07-2018, 10:27 PM
GTOGEORGE's Avatar
Why do you need more the a 3 gal tank?
GTO George
  #625
Old 09-07-2018, 11:05 PM
GTO George
Each run uses about 2 1/2 gallons, any delays at the line and I will run out of fuel, or worse run lean down the track
Glenn R. Lever
  #626
Old 09-08-2018, 12:21 AM
GTOGEORGE's Avatar
I have a 3 gal fuel cell and I can make a 1/4 mile pass and drive it back to my pit spot.
GTO George
  #627
Old 09-10-2018, 09:47 PM
Dragster Update 09 06 2018
First off, Steve thanks for your help once again.
In this video, we install a converter to step down the voltage out of the 16 volt Turbo Start battery to 12 volts. This was done to run the filament bulbs on 12 volts so they would not be very bright and hot.
This allowed us to remove the small trailer break away battery we were using and install a fuel primer pump in that location.
We also started the engine for the first time after the latest rebuild. Set the timing on the mag and the crank pickup.
Once the engine was hot we were able to set the valve lash (this is an aluminum block and also has aluminum heads).
Another mystery was discovered, which we do not have a clear answer to. Your input on that mystery is welcome.
https://www.youtube.com/watch?v=lfDR...BEt8iqd4rYh7MQ
Glenn R. Lever
  #628
Old 09-11-2018, 04:29 PM
GTOGEORGE's Avatar
When i lash my valves I do it with the engine cold also I remove the spark plugs to make it easier to turn the engine with a breaker bar. How much timing are you running and what kind of boost are you at during the run?
GTO George
  #629
Old 09-12-2018, 02:33 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by Glenn Lever View Post
... Another mystery was discovered, which we do not have a clear answer to...
Tell us about it...
  #630
Old 05-14-2019, 10:10 PM
2010 Front Engine Dragster and Trailer walk around
There are separate build pages for both these vehicles on my web site.
Current date is 05/14/2019
https://www.youtube.com/watch?v=ReFJ...BEt8iqd4rYh7MQ
It may be time?????
Glenn R. Lever
  #631
Old 06-02-2019, 09:32 PM
For Sale
$40,000
complete racing outfit class a motor home, trailer, equipment, pit vehicle etc. is available, dragster and motor home go first
ID:	513428   Click image for larger version
ID:	513429   Click image for larger version
ID:	513430   Click image for larger version
ID:	513431   Click image for larger version
Glenn R. Lever
  #632
Old 06-03-2019, 08:33 AM
Elarson's Avatar
Elarson Elarson is offline
Oh no!!!!!!
We all have changes in life's directions. I'm sad to see you sell after all the work and money that you've sunk into it.
$40k is an absolute steal.
Eric
  #633
Old 06-03-2019, 09:55 AM
Yes sir the engine cost that much
Glenn R. Lever
