Tri-Power Tech 57-66 Tri-Power Talk
Old 03-07-2017, 10:21 PM
ReelFun's Avatar
ReelFun ReelFun is offline
Default 65 Tripower Fuel Line to Pump
Does anybody have diagram or photo of how to run the fuel line from the carb to the fuel pump? I have the metal line that attachs to the carb, the fuel filter and bracket. Is there another metal line that runs from the filter to the pump?
1965 GTO
389 Tri-Power
4-Speed
Johnny
Old 03-07-2017, 11:24 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
Rubber hose from the fuel pump up to fuel filter, then another short piece of rubber hose up to the metal line that goes to the carb.
Old 03-08-2017, 12:09 AM
ReelFun's Avatar
Thanks, and the fuel filter mounted to the outermost WP bolt?
1965 GTO
389 Tri-Power
4-Speed
Johnny
Old 03-08-2017, 02:09 PM
Dick Boneske's Avatar
The fuel filter is mounted on the stud that holds the timing cover on the engine. You can see the nut holding the fuel filter bracket on in the picture.
Name:	Engine Ready for Radiator 006.jpg
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 03-08-2017, 09:21 PM
ReelFun's Avatar
Thanks Dick, that helps.
1965 GTO
389 Tri-Power
4-Speed
Johnny
