Old 06-08-2009, 04:11 PM
Bill Meyer's Avatar
Bill Meyer Bill Meyer is offline
Location: West St Paul MN/Mesa,AZ- depending on weather
Default '67 Intake manifold/gasket
I'm rebuilding a '67 GTO engine for a friend. The intake has a passage in front of the primaries. I seem to remember the gasket for the '67's had a metal insert or something like that to keep those hot gases from blowing out the carb base gasket. The replacement gasket doesn't have anything like that. In fact, some of them don,t even cover those holes in the manifold.
* What are some options here?
*Are people plugging those holes to keep the heat out?
* Something just doesn't seem right......Thanks, Bill
GT37 3625lbs..Fastest bench seat, column shift, all steel,no power adders car at Norwalk
1.35 w/29.5x10.5x15
6.42 @ 109
10.09 @ 133
Old 06-08-2009, 04:53 PM
screamingchief's Avatar
screamingchief screamingchief is offline
Yes,the '67 intake is the same as most of the same era chevys were,there are two thin high temp metallic/paper style gaskets sandwiching a thin sheet metal "insert" gasket.
And yes these gaskets & insert are never ever included in the common gasket sets,they usually need to be ordered seperately,especially seeing as they are one year only for pontiacs.
And yes if so desired,the cross-over channel can be plugged,and then regular carb gaskets can be used.
In the past I have used both small press in style cup plugs,or tapped the holes and use a standard pipe plug of the appropriate size.
If you can find a parts guy with half a brain,he should be able to look up and find the proper gaskets & sheet metal insert,but he'll likely need to crack open his gasket catalog to find that stuff,and most counter guys these days seem to resist doing that sorta "extra credit work",they just tell you "well it's not in my computer sir".
Anyhow,you seem to know all this already.
Good luck.
BP.
This space for rent...
In the meantime,check out the cars HERE.
Old 06-08-2009, 05:07 PM
Region Warrior's Avatar
Plug'm.
Old 06-08-2009, 08:42 PM
Cliff R's Avatar
Cliff R Cliff R is offline
"And yes if so desired,the cross-over channel can be plugged,and then regular carb gaskets can be used."
Not exactly that easy. The passage was made a tad wider on the drivers side so that most standard gaskets are NOT wide enough to seal it off. We stock at least one .230" thick gasket that is wide enough.
This was probably done to make it somewhat tamper-proof, or to at least make it difficult to use gaskets and such from other years. Keep in mind that those intakes were the result of very early emission standards being brought into place.
Anyhow, I do recomend plugging the openings, we tap them here for plugs. I also take some nickle welding rod and close off the extra wide portion of the drivers side channel, then machine it flat. This allows almost any Quadrajet flange gasket to work effectively under the carburetor.
Another very good repair is to make a thicker version of the factory thin steel plate. Use the stock channeled gasket under the plate, then pretty much whatever you want on top of it.
We have new stainless steel plates and the correct gaskets in stock if you decide to leave it alone and need the correct parts?......Cliff
Old 01-26-2010, 09:31 AM
wbob69's Avatar
wbob69 wbob69 is offline
Default .230 gasket
Cliff;
I have the botom gasket and the stainless top gasket and was thinking of using a standard felpro gasket on top....in other words sanwhiching the stainless plate between 2 gaskets. I think this will work but am interested in possibly just using the one .230" gasket that you mentioned. Can you tell me if you have one and how much? By the way I tapped my intake holes and put in plugs, but do not have easy acesss to weld or fill the driver side, so gaskets are the way I would prefer to go.
Bob
Old 01-26-2010, 10:18 AM
Cliff R's Avatar
I'll take a look in a few minutes when I get to the shop to see if we have any left. Those parts were very slow movers, not sure if we restocked them due to lack of interest?
If you have effectively plugged the openings into the exhaust crossover, then the stock gasket, with or without a plate should work fine. The vacuum leak from the channel into the intake is internal, and woln't happen as long as the gasket under the carb covers the intake and channel.
The very best set-up for those intakes, plugged exhaust channel or not, is to make a thicker plate, stock gasket under it, then just about any gasket you want on top of it......Cliff
Old 01-27-2010, 07:30 AM
Cliff R's Avatar
I found one gasket in the shop that should work, it barely covers the channel, but does cover it.......Cliff
Old 01-27-2010, 08:10 AM
wbob69's Avatar
Default thanks
If it is the thick .230" gasket I will take it. I would prefer to use just one gasket. Let me know how I can pay and get it shipped. my zip is 49825. Also I need to know if you ship UPS or USPS.....I live in a rual area and have to pick up my mail at the post office. UPS however does come to my house, so I have to use different address depending on how it ships.
Old 01-27-2010, 08:42 AM
Cliff R's Avatar
I didn't measure the thickness, probably closer to .150"-.180", wasn't as thick as our .230" gaskets. It had enough material to cover the outer edge of the channel, but barely. None of the other gaskets even came close.
I used to stock the wide/thick gaskets for those intakes, sold one about every 10 years so we didn't restock them, and I'm not even sure if they are still available?.....Cliff
PS: no longer listed from any of our suppliers....
