Dyno Results IAII
I thought I would post some dyno results from an engine I recently built.
IAII - 505 w/ one of those 4.25 stroke $699 cranks. Here are some of the specs: 4.35 Bore - Ross pistons Eagle 6.8 w/L19 upgrade Comp Cam 283/283@.050 .747 lift (measured w/HS) Kaufman Hi port heads w/std pushrod location and 380cfm option. Installed as received. Harland Sharp 1.5 roller rockers, Roller lifters, 3/8" Smith Bros pushrods Edlebrock Victor intake. Carb used was 1250 Holley from dyno shop - made more than customers 1050 by 14 tq and 28 hp. This engine wanted the 1250! MSD distributor-locked in@32. RPM TQ HP 4700 675 604 4900 685 639 5100 687 667 5300 700 707 5500 696 729 5700 687 745 5900 679 763 6100 671 780 6300 661 793 6500 649 804 6700 636 811 6900 617 811 7000 607 808 Stopped here! I thought I would share this for those looking for a fairly reasonable high performance Pontiac!!! - Bill -
GT37 3625lbs..Fastest bench seat, column shift, all steel,no power adders car at Norwalk 1.35 w/29.5x10.5x15 6.42 @ 109 10.09 @ 133 |
I want one.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' |
Very nice numbers! Congrats!
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
nice build
what octane race gas used ?
someone who thinks logically is a nice contrast to the real world. http://www.youtube.com/watch?v=3FfKVVZW1-Y |
Congrats--nice.
The Bandit Rules - Make mine with a SD-455 Engine . |
Great Job, what kind of car.
Nice build. Was their any porting on the Victor? CR?
68 Firebird Are you running with the wind or breaking it? |
Thank you for the nice complements! The compression ratio was 13.7:1. I used the 64cc version. The Victor intake was cleaned up on the top and intake seperating fins and opened up on both the top and bottom to match the hi-ports. VP C12 racegas was used. It's going in a '73 Ventura - Bill -
sounds like a low to mid 9sec ride depending on the weight.Nice!
Mark 1970 Lemans Convertible,462,6x-4, 234/242 cam.3.42 posi.12.55@109,4100 lbs...SOLD.... 1968 Firebird , 467 , KRE d-ports ,stock type suspension,3100lbs (1.30 60')(6.08 1/8)(113.43)different runs 9.59 @140.71 on E85 all motor 8.97@148.63 on 150 shot |
Sweet, better hang on!
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
Bill-Any idea what the cc's the intake runners are? 700 lb ft you could tow the Titanic.
Jack Ferris RestoRacing LLC www.restoracing.com Sandy, UT --------------------------------------------------- |
Always nice to hear about high HP Pontiacs close by.
This going into a bracket car for Grove Creek, Rock falls, and or BIR?
************************************* 463 SRP .035 Pistons, Eagle rods, N crank, Pump gas, Victor intake, Holley 850BT carb, 6H heads,TH400 w/T-Break, Continental custom 3500 converter, 3.73 gears. TV7101 TURBO! |
Nice job Bill!!
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
One other note on Bill's 505 build.... this motor did not have a vacuum pump and was minimally optimized. I bet there was 30 easy hp left on the table. Impressive HP/$$ for a Pontiac.
yep, hps are best bang for the buc.......
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
Wow, nice project.
What are the details on the Ventura? ( caged, minitubbed etc etc) |
Large chambered HP's s-480 =??? Killer strip combo......
nice #s. good luck with it!
What size headers?
