71 455 HO non-ram air air cleaner question
My HO GTO is a non-ram air, numbers matching car but is missing the original air cleaner. Does anyone have pictures of an original? I have seen a couple of pictures from the top on a GT37 but they don't show the bottom which I think is where they are different than a regular dual snorkel air cleaner. If anyone knows where I can find an original that would be great too. Thanks.
Passenger side snorkel has a heat riser connection, it's the same visually as the one on the driver's side snorkel.
Like hens teeth to find and mucho $$$!!!! I have been looking for a couple years for an affordable one and no luck! Don't want to say what they are price wise.
OPH could it be poss to make one with an extra snorkel? I have a few dual snorkel units.
Would it pass the sniff test? Thanks Dave |
I just picked up a 71/72 shaker air cleaner that I'm going to use for the time being, I'll just knock off the little ears that hold the scoop on and use a larger lid.
I know it's got the deep dish on it, but until I find a correct one....
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
I was lucky to get one for my car from Lynn. They are hard to find!
Mike/Illinois |
Scott |
That sticker is hideous! Put a real one on!
Pat Brown |
Shouldn't even have one on an HO T-37 or GT-37 or LeMans.
not true roger, both of my HO lemans came from original owners and both of them have the stickers on them.
Pat, that is a before picture. You were not producing them at that time. All is fixed for now! Roger, Mine will!!
Here are some good pix of the one I bought from Lyn. http://forums.maxperformanceinc.com/...d.php?t=681099
Mike/Illinois |
...and the thermac nipples point the wrong direction.
1968 Firebird 400HO convertible 1971 Trans Am 4-speed, white/blue |
... and the spacing between the snorkels is different than '70-72 A-body & there's a big recess in the back of the early 2nd Gen dual snorkels.
Question
So the 455 HO air cleaner base has two heat risers and is there any other difference from say a 69 dual snorkel unit? Is base lower? I ask because I have a few of these and never really took a close look at them etc. I will never need them as my cars are 69 ram air. I will dig them out over the next couple of days and check what they look like. Probably just plain dual units but never know. I learned something new today. |
1971 Pontiac GT-37 Car is a junk yard dog and maybe one day will be restored. |
Hey Mike, Are we going to see the GT at Dayton this year?
Lyn.
'72 400 M22 4-speed Lemans Sport GT '72 400 4-speed Luxury Lemans '72 Luxury Lemans 4dr. hardtop 45,000 mile car '72 Lemans 2dr. 20,000 mile car [sold] '73 Grandville backhalfed Drag Car '73 Grand Am 400 4-speed '74 Lemans Sport Coupe-4800 original miles |
Yes and heat riser connection on pass side.
'69 GTO aircleaner bases are different. Wider spread between the snorkels. The '69's also, nearly always have the snorkels with the ribs stamped in the,
The only difference between the standard 71-72 GTO and 455HO dual snorkel air cleaners is exactly what OPH said, that there is a ring on the bottom of the HO air cleaner passenger side snorkel for the hose to connect to (just like on the bottom of the driver's side). The thermacs are complete on both snorkels for both the standard and HO air cleaners. All you need to do is get one of those rings off of another air cleaner (they used that same ring on all sorts of air cleaners for various GM cars and years), cut the hole and tack weld it on. That is exactly what the factory did. Cutting snorkels off other decent air cleaners (and re-orienting the thremac), modifying/destroying rare and expensive TA air cleaners, or holding out for a hen's tooth is overkill.
Maybe we could get someone like Norwood to repop that ring ;>)
1968 Firebird 400HO convertible 1971 Trans Am 4-speed, white/blue Last edited by 68bird400HO; 01-24-2013 at 02:04 PM. |
