Old 10-01-2017, 10:17 PM
Bully goat 2 Bully goat 2 is offline
Default 70 gto 10 bolt
Hi guys planning to swap my 10 bolt rear for a 12 bolt rear car is a turbo 400 will the driveshaft be the correct length?
Old 10-02-2017, 02:55 AM
Kenth's Avatar
Kenth Kenth is offline
Yes, however you'll need a 3R to 1310 conversion u-joint.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 10-02-2017, 06:21 AM
AG's Avatar
AG AG is offline
X2. I just did this for my brother's car.
Old 10-02-2017, 09:40 AM
Evil Stu's Avatar
Evil Stu Evil Stu is offline
Is this true if you have a 12 bolt from a 70 GTO (as opposed to the more common Chevy sourced ones)?
"Having a 10 second Civic must be just like coming out of the closet; you'll surprise some people, but you're still gay"
1970 GTO, 455+.034", 0 deck, Wiseco's, Eagle rods, 60919, Rhoads, E-Heads, 1.65 Scorpions, RPM, Custom Qjet by Cliff, Doug's 1 7/8", THM 400, Gear Vendors OD, 3.55s.........Her name is Blandorf; after a girl I knew once, 'cause she's just Bitchin, always.
Old 10-02-2017, 09:58 AM
No, not true, the original 12 bolts used in the '70 GTO's are direct bolt in, a have pinion flange that accepts 3R ujoint. Same deal with many other McKinnon built 68-72 12 bolts.
Old 10-02-2017, 11:52 AM
Kenth's Avatar
No issues with u-joint using a 1970-72 Pontiac (McKinnon) 12-bolt rearend.
Also some trimming of one upper arm at the rear bolt hole will be necessary.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
