Carburetor recommendations
I'm going to replace my carb soon and was wondering what I should get for cfm. Its a 350 2bbl soon to be a 4bbl.
Get a QJ for the year of your car.Tom
The Following User Says Thank You to tom s For This Useful Post: | ||
I've tried that route, cores I have found are junk or over priced. I'm looking into an Edelbroc AVS2.
This. Get a new carb... it's new and works.
The Following User Says Thank You to thews For This Useful Post: | ||
Contact Sean at SMI and get a price for a done QJ for your application.Tom
If it’s not a restoration why pay big money for an inferior early Q-jet?
Plenty of reasonably priced ‘77 and later Q-jet cores are out there and are a far better design.
The Following 4 Users Say Thank You to b-man For This Useful Post: | ||
What would the recommended CFM for a 350 be? 500 or 650?
Cliff had been giving his approval, to quadrJet power, in Houston. I'd gat a 77 and up unit from them, as ;art mentioned, get it with an alactric choke!!!
The late ‘70s 350 smogger engines were all equipped with 800 cfm Q-jets.
Hard to go wrong with a late model 800 cfm core that’s been redone by an expert.
The Following User Says Thank You to b-man For This Useful Post: | ||
The avs2 carbs get rave reviews, I would like to hear back if you try one.
X2 on Quadrajet power… Can’t go wrong
Brent Flynn is still rebuilding QJets and recently did one for me.
I installed a edelbrock intake and a 600 performer carb, it runs good and seams to have woke up the engine.
It is your car, and if you are happy, that is all that really matters! Jon
"Good carburetion is fuelish hot air". "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
The Following User Says Thank You to carbking For This Useful Post: | ||
My only advice is to check and double check the credentials of any so called "expert" if you have anyone rebuild one for you. I am in a 4 month ordeal trying to get my quadrajet back from a guy. Also that quadrajet is replacing a Edelbrock 750 cfm , my buddy has almost the same motor/tranny setup and is always getting better fuel economy with his QuadraJet then I am. And his car runs hard with the QJ. if your interested in an Edelbrock I have one I will sell if I ever get my QJ back.
Let's make welfare as hard to get as Veterans benefits! |
Enjoy it and if you need help doing any tuning glad to help, I'm just a town over.
Carburetor building & modification services Servicing the Pontiac community over 20 years |
Thanks Jeff, I will keep that in mind.
Rob, could you give an update on your performer 600? Some gifted me a Qjet, but it’s from national carb, runs but not right. I was looking at that the performer , a street demon 625 and brawler.
There is no "best" carburetor for all applications.
If you want best driveability, fuel economy, power, and reliability; then the Q-Jet, as mentioned by many in this thread, is the way to go. If you want lots of "wow" from the 16-year-olds at the local car show; then go with the shiny new imitation. Jon
The Following 3 Users Say Thank You to carbking For This Useful Post: | ||
