Old 07-06-2014, 02:55 PM
*67firebird*'s Avatar
*67firebird* *67firebird* is offline
Send a message via AIM to *67firebird*
Default Fs: 67 firebird Subframe
I recently purchased an aftermarket frame. I would like to recover some of the cost by selling my stock frame and suspension
Comes with:
Upper and lower control arms
Springs from a 6cyl firebird, monroe shocks
Spindles
Master cylinder, prop valve disc/drum.
Brake rotors, calipers, pads, dust Shields, caliper brackets.
Converted 4 piston to single piston brakes.
Steering components including pump, gearbox, lines,
I started sand blasting the frame and control arms, but it needs some more to finish up.
It needs new mounting plates welded in. And there are some cracks that need to be welded.
$750
local pick up preferred.
Thanks for looking,
Ozzy.
463 Stroker Kit.
ross pistons. h beam rods. eagle crank.
62 heads 72cc, port matched
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 07-06-2014, 04:50 PM
The pictures below show the cracks on the Control Arm towers that need to be welded, both driver and passenger sides, corrosion on one of the body mounts, and of course the frame.
ID:	369250   Click image for larger version
ID:	369251   Click image for larger version
ID:	369254   Click image for larger version
ID:	369256   Click image for larger version
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
