Old 10-25-2023, 01:32 PM
461-69bird's Avatar
461-69bird 461-69bird is offline
Smile Dyno results
Picking the engine up Friday. I'll post the dyno sheet then but it made 542hp and 581tq.
400 bored 4.155
Eagle forged crank 4.350
Billet splayed caps
SRP flats
Eagle H beam rods
Melling 60lb pump
Victor intake
KRE 85cc d ports ported to 300
9 way billet double roller
Holley 850xp
Bullet solid flat tappet cam
250/256, 606/607, installed at 104
34deg timing
Builder says carb is holding it back from full potential but I sold my Dominator as it was too much on the street for mpg.
I'm happy with the results after a few problems with the build that the dyno found. Can't wait to get it on the Firebird and try it on the street. No track testing until next year as our season has finished now.
69 Firebird
472, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 10.90 @123
The Following 4 Users Say Thank You to 461-69bird For This Useful Post:
Old 10-25-2023, 01:35 PM
Sounds good!
What was the HP of the engine in your signature?
Old 10-25-2023, 01:45 PM
461-69bird's Avatar
611hp 601tq. Solid roller cam with a 1050 dom but everything else the same as this build.
69 Firebird
Old 10-25-2023, 02:49 PM
Cool.
Thanks for the info.
It'll be interesting to see what it runs when spring comes around.
Old 10-25-2023, 03:06 PM
Glad to hear no damage was done with the low oil pressure issue.
Old 10-25-2023, 04:48 PM
461-69bird's Avatar
Yes Steve, got lucky with that
69 Firebird
Old 10-25-2023, 05:22 PM
At what rpm where your peaks showing up at?
Old 10-25-2023, 07:14 PM
461-69bird's Avatar
I think he said torque was 4100 can't remember the hp. I'll have the sheet Friday
69 Firebird
Old 10-25-2023, 09:35 PM
Very nice results.
....had an UD cam with the 104 LC just like that in a 472. The 104 LC was set to 100/108 for Street effect. Idle pulses out the tail pipe were impressive.
Hmmmm, have a 1970 1050 sitting on the shelf, doing nothing for nobody now.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 10-26-2023, 12:36 PM
i82much's Avatar
i82much i82much is offline
Is an 850 carb really a restriction on a 550 horsepower engine? Hmm.
Headers are 1 3/4 or 1 7/8?
The Following User Says Thank You to i82much For This Useful Post:
Old 10-26-2023, 01:19 PM
461-69bird's Avatar
Well he thinks it could make 600 with a bigger carb. Headers are stepped Maddog 13/4 to 17/8
69 Firebird
Old 10-26-2023, 01:55 PM
i82much's Avatar
any chance it wants more timing? 34 degrees seems low. compression?
Old 10-26-2023, 01:56 PM
slowbird's Avatar
slowbird slowbird is offline
Just curious how much bigger is he thinking?
Old 10-26-2023, 03:57 PM
461-69bird's Avatar
Those heads with my 290b were best at 32 with 10.2 comp.
With the solid roller 34 at 10.75.
Now 34 at 10.8 seemed the best
He would like to see a 1000 or a dominator but that's not what I'm ever going to run so wasn't much point. Would be fun to borrow one at the track just for a few runs though.
69 Firebird
Old 10-26-2023, 07:35 PM
mgarblik mgarblik is offline
Did they have an air hat on the engine dyno? It would be interesting to see how much air that combination actually used? Also, if no air hat, did they have a vacuum line on it for manifold vacuum?
Old 10-27-2023, 06:13 AM
Yes, like menshined above , a vacuum reading take below the Carb at 500 rpm below peak hp will tell you if your Carb is too small.
Old 10-27-2023, 08:01 AM
slowbird's Avatar
Why 500rpm below peak??
Old 10-27-2023, 10:18 AM
FWIW my 500" IA motor that dynoed 695 HP made the same with an 850 4150 as a 1050 Dominator on it.
I can tell you dynoing my friends 463 E head motor that made 640 HP with 2" headers we killed 40 hp swapping on my 1 3/4-1 7/8 Hedmans
Old 10-27-2023, 10:59 AM
Stan Weiss's Avatar
Depending on what other numbers are on the dyno sheet, it is possible to calculate SCFM. I was talking with Larry Meaux once about measured and calculated A/F ratio on the dyno and how close they were. He said very close. He said once they were not and he checked his air hat and it was off.
Stan
Pontiac Pump Gas List
Old 10-27-2023, 01:07 PM
prostreet64's Avatar
prostreet64 prostreet64 is offline
Skip, was the header swap the only change? I know on my 463 with KRE heads I am giving up some hp with the 1&3/4" headers but I didn't think it would be in the 40 hp range.
Also on the carb issue I am running a QF 950 that I discovered is more than I need. Factory jetting was at 86/78. I am down to 82/74 and it is still rich, at least in warm/humid air. Will probably be pretty close when the cooler/drier fall air gets here.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet.
