Old 08-16-2022, 11:18 AM
Defire78 Defire78 is offline
Default Headlamp Upgrade
To All,
Would like to upgrade the standard square headlamps on my 1978 Firebird T/A to the more modern halo style lights. Looking for suggestion(s) on companies to but such a setup and is install quite difficult? Would appreciate your input. Thank you.
Old 08-16-2022, 08:39 PM
bhill86's Avatar
bhill86 bhill86 is offline
Curious what you mean by “halo” style lights.
1977 Trans Am 400/4speed (swap)
Brian
Old 08-17-2022, 09:50 AM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
Guessing bulbs like these? I've seen them in classic cars and liked them, and I've seen them in classic cars and not liked them... I'm not sure what makes some look good and others not. Maybe color?
Mike
Old 08-17-2022, 11:06 AM
Thanks for the reply. Yes, some look good and not so good. That is why I am inquiring about other companies. Note the attached. This style is from Top Gear. Again, are there other companies that supply aftermarket headlamp styles and the level of difficulty.
Old 08-17-2022, 06:24 PM
62posbonny 62posbonny is offline
Most cheap LED replacement headlights are trash. I get the look you are going for, but spend some time researching the bulbs you are considering before buying. The beam patterns on some are detrimental to the vision of oncoming traffic and don't necessarily provide good swaths of light for the driver. Another issue is the actual lumen output can be abysmal for cheap bulbs. Combine these two issues and you end up with a downgrade rather than upgrade.
Old 08-17-2022, 06:48 PM
omarsphatt omarsphatt is offline
Best ones I've found are sold by The Retrofit Source - www.theretrofitsource.com
Old 08-18-2022, 06:26 PM
Thank you very much. I'll give them a call.
