Old 06-02-2022, 03:17 PM
ho421's Avatar
ho421 ho421 is offline
Default HS Roller Rockers
Question. I'd like to replace the PRW stainless roller rockers in my 421 with Harland Sharp rollers. Will they fit under my stock valve covers? I'm using a 5/16" butler VC gasket currently. Thx in advance. Bob
Old 06-02-2022, 03:53 PM
25stevem's Avatar
25stevem 25stevem is offline
I have no direct experience with them on Pre 1967 heads, but I would think that as long as your heads are not fitted with longer then stock valves, then you will have adequate clearance.
I do stuff for reasons.
Old 06-02-2022, 04:10 PM
JLMounce JLMounce is offline
I have the HS 1.5's on my KRE heads and a cheap set of stock style valve covers fit with a standard cork gasket. You may just need a thick or double gasket, depending on the differences in head depth.
-Jason
1969 Pontiac Firebird
Old 06-02-2022, 05:18 PM
tom s tom s is offline
WHAT valve covers?Tom
Old 06-02-2022, 05:22 PM
25stevem's Avatar
With the early 20 degree valve inclination heads and stock valve covers it may be a question of how much lift you can run before the push rod end hits the valve cover.
Old 06-02-2022, 07:31 PM
gpguy gpguy is offline
if this is any help...I put the Harland Sharp 1.6s on my 71 455 with stock chrome covers and thick gaskets and had to use short polylocks as they long ones hit the valve covers.
GP.Style
70 GP SJ White/Blk/Blk
71 SJ 455 4 spd Blk 3X
72 J Sundance Orange/Wht/Wht
The Following User Says Thank You to gpguy For This Useful Post:
Old 06-02-2022, 09:07 PM
ho421's Avatar
63 HO valve covers Tom. I have the polylocks now. This was the setup recommended by Dave Bisshop a few years ago when I built my motor. He worked my HO heads and supplied my stump.puller cam
Old 06-02-2022, 09:09 PM
I think it might be tight with 63 covers,the HOs have stacks which is the diff but no taller.The 69-70 stock covers work fine with 660 lift on H&S 1.65s with 5/16 gaskets.Tom
Old 06-02-2022, 09:11 PM
No matter what you’re going to need at the very least some thicker gaskets and quite possibly some thin spacers.
There are some pictures of how well the valve covers cleared the Crower rockers on my 421 HO linked here:
https://forums.maxperformanceinc.com...0&postcount=34
Old 06-02-2022, 09:12 PM
ho421's Avatar
Probably why they pushed the PRWs. I suppose the Crowers would be fine? 1.52s
Old 06-02-2022, 09:45 PM
ho421's Avatar
Were those the shorter polylocks? Thanks for the reference by the way
Old 06-02-2022, 10:00 PM
Those must have been the same polylocks that came with the rockers, I don’t see any extra polylocks I bought in my list of parts.
Old 06-03-2022, 08:43 AM
rwfisher's Avatar
rwfisher rwfisher is offline
You may also have issues with an end rocker rubbing the radius of the valve cover. I had to slightly grind my HS rockers on the corners for clearance.
The Following User Says Thank You to rwfisher For This Useful Post:
Old 08-28-2022, 02:16 PM
ho421's Avatar
How much did you have to remove.. with 1/2" gasket, ps end rocker is making.contact with the oem ho stack valve covers. Sorta wishing I had gone with crowers at this point
Old 08-28-2022, 02:36 PM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
I have HS 1.5 rockers on my 66 389 with 5/16 gaskets. I have the stock 65 covers with no issues
Old 08-28-2022, 04:23 PM
ho421's Avatar
I have these with 1/2" gaskets and they are making contact
Old 08-28-2022, 04:40 PM
25stevem's Avatar
If it’s the push rod side of one of the end rockers it does not take much metal removal on the rocker to gain the needed clearance.
Pull a rocker cover remove all the oil from each end and then color it with a big marker and then reassemble everything.
Crank the motor a few times and you will then see where the issue is.
Thread Tools
Display Modes
