THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
What is this?
Found this while cleaning the garage.
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
Looks like a big heat sink for charging a battery? someone here will know for sure
72 Luxury Lemans nicely optioned These cars are meant to be driven, so enjoy the hell out of all of it - not just look at it when it's clean. |
I think it's a Solid State Battery Protector.
That's the limit of my helpfulness
I'm World's Best Hyperbolist !! |
Possibly a one way charging module for a secondary battery. Allows the second battery to charge but not discharge the primary(starting) battery when a load is applied.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express |
The Following User Says Thank You to OG68 For This Useful Post: | ||
Found this after a quick search
It's an RV charging system splitter. You need to isolate the "car" battery from the "house" battery when charging them by the alternator while driving the RV.
Typically the house battery also gets charged by a charger that runs off 110VAC, either plugged into the campsite power or when running the generator. Side note, that requires an ATS, or automatic transfer switch. You'd need the same type of switch for your home if you hard-wire a whole-house generator so the guys working on the power lines during an outage don't get electrocuted from backfeed power from your house. |
The Following User Says Thank You to einstein For This Useful Post: | ||
Alum scrap
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8” Flakes F ire B irds 🇮🇱 |
Hehehe ... that made me laugh.
battery isolater. used to charge 2 batteries and if one goes dead from use without the machine running the other battery stays charged to start the machine. Often used on boats limos and cars running stereo without the car running
The Following User Says Thank You to stellar For This Useful Post: | ||
Also commonly found in pickups with dual batteries and tow vehicles with batteries in the trailer that are charged by the truck. They were factory options as far back as the late 1960's on GM's and other manufacturers.
Allowed you to run the lights in your camper all night and still be able to start the engine in the morning
If it breaks. I didn't want it in the first place. _____________________________________________ 69 GTO \ 72 FIREBIRD \ 1/2 OF A 64 GTO \ 70 JAVELIN \ 52 FORD PU \ 51 GMC PU \ 29 FORD PU \ 85 ALFA ROMEO SPYDER \ A HANDFUL OF ODD DUCATI'S \ 88 S10 LT1 BLAZER & MY DAILY DRIVER 67 SUBURBAN. |
The Following User Says Thank You to VCho455 For This Useful Post: | ||
I thought it was a McGanzer Flange but dataway would've recognized that.
Guess it's that charging circuit isolator module thingy... Frank
Poncho Huggen, Gear Snatchen, Posi Piro. |
The Following User Says Thank You to 4zpeed For This Useful Post: | ||
Typically, no. The isolator does just what it's called, it isolates the second battery from the rest of the vehicle's original electrical system Here's a typical schematic, there are a number of them online (just search for 'RV battery isolator wiring diagram'.)
The Following 2 Users Say Thank You to Stuart For This Useful Post: | ||
Actually my 2011 GMC has one built in, cables hanging by a spare battery tray just waiting for the battery I never installed.
While it looks sophisticated, it is still a couple of diodes with a big heat sink. I had problems with them and prefer a simple large solenoid switching the RV battery in line when when the ignition switch is on (and isolating the two when ignition is off). Maybe it was just luck of the draw, but I had two isolators where the diodes didn't switch off and drained the vehicle battery. The local RV repair said they replace them with the old reliable solenoid when the isolators go bad. Might be why this one is in your garage instead of installed.
I think it's missing a McGanzer Flange, would probably work great if it had one.
the ATS is unrelated to the battery isolator. That's why I wrote "side note" as I was referring to the 110 volt AC circuitry.
Thread Tools | |
Display Modes | |
