Anyone use a ho- racing hc-02 cam without rhoads lifters?
Most reading i have done on this cam indicates usage of rhoads lifters, to tame the idle quality, ect as rhoads lifters do. But everywhere i look, rhoads is way backordered. Out by months. So i am looking so see if anyone has run without them and how your car responded. Or if anyone has a new set of rhoads they would care to part with, i would be interested in that as well. Thank you
1970 Formula 400 4 speed 2006 Gto. Ls2/m6 1972 Gto 455ho/th400 post coupe 1973 Grand Am 400 4 speed |
That cam in a 400 or 455 will be fine with most lifters. Johnson hylift would be my choice
Sent from my LG-G710 using Tapatalk
1972 HO Trans Am auto White/white 1974 SD Trans Am 4 spd, no a/c dk blue/ white & blue 1978 Trans am gold/ black ,T56, t tops, EFI 474, Build: http://www.pro-touring.com/showthrea...1978+g+machine 1999 30th Trans Am 6 spd, T top |
I also ran their HC03 in a roundport 455 with normal lifters. Never an issue with vacuum.
Hc-02
Ran it 25 years in a manual trans 400. Pulled excellent to past 5500 ,and nice idle. You definitely do not need bleed down lifters
The H-O cam spec sheet I have describes the HO-02 as 744HL Do you have a cam card? What size engine are you going to install the cam in?
Stan PS Let add this H-O Recommendation Chart - Not very easy to read.
Stan Weiss/World Wide Enterprises Offering Performance Software Since 1987 http://www.magneticlynx.com/carfor/carfor.htm David Vizard & Stan Weiss' IOP / Flow / Induction Optimization - Cam Selection Software http://www.magneticlynx.com/DV Download FREE 14 Trial IOP / Flow Software http://www.magneticlynx.com/DV/Flow_..._Day_Trial.php Pontiac Pump Gas List http://www.magneticlynx.com/carfor/pont_gas.htm Using PMD Block and Heads List http://www.magneticlynx.com/carfor/pont_pmd.htm Last edited by Stan Weiss; 12-18-2021 at 05:29 PM. |
the HC-02 will fast idle (800rpm) with about 11-13 " vacuum
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
The Following User Says Thank You to KEN CROCIE For This Useful Post: | ||
Stan, i do not have a cam card. I found a couple online. Its going in a mostly as built 72 455ho, mid 8's on cr. th400, 3.08 gear 72 gto. Stock converter, with a/c and power brakes.
Ken, is that without rhoads lifters? Also have some ho racing vs-13 valve springs. Anybody know if these are to aggressive? Man i wish i had a ho catalog that had some insight on these parts i have.
This is one i have found for the hc-02
Hc-02
I had 13 inches vacuum in the 400
The 744 High Lift from Wolverine Cams is similar.
A 455 engine with that camshaft made 12" of vacuum with the cheap gage we had. Tom V.
You can’t nail down vacuum numbers because the smaller the chamber in the head is the higher the vacuum will be.
All things being equal a 455 would have almost 1.6 inches more vacuum then a 400 at the same rpm.
THE ENGINE IN MY POST #11 HAD 87CC ALUMINUM HEADS.
Tom V.
I am
In a 10.1 cr 400, KRE, HS 1.65's. This is the 'cam card' I got when I bought it in the middle 80's. I went with the recommended lifters and springs. I'm fairly certain the lifters are not Rhoads or bleed downs. 10.5 - 11" vac at 750 rpm. I'm finding it just a bit difficult to keep my foot out of it. I do have a vid of it idling, if you like.
Frank M. 75 Firebird 68 Firebird 400 RAIII 66 Chevy II 461 Pontiac in AZ |
Tooski, According to that information, the camshaft info you supplied from the camshaft you bought in the 80s is a true RA-IV type grind not a 744 grind. The 231/243 is very close to stock Pontiac RA-IV duration specs at .050" lift checking points.
Tom V.
Tom, that's what I thought; but, in one of the RA-IV cam streetability threads I posted the same info and was told there was no comparison because a real RA-IV had quite a bit more overlap.
My brother ran an HO Racing HC-02-A with standard lifters in an automatic, stock 1971 455 H.O. Blue with White Stripe Trans Am. I don't have the camshaft card anymore, but I specifically remember it reading 301/313 Advertised Duration, 232/242@.050, .465"/.469" lift, and 112° Lobe Separation. It ran really well for a basically stock 1971 455 H.O. with stock, low 8-1 compression. It had mild stuff done to it, like a HO Racing distributor advance curve kit, and maybe some different Primary/Secondary Rods for the factory Qjet. He ran the Crane HI-6 ignition, Super Duty rods, Forged flatop pistons and it was Balanced. It had stone stock 197 HO heads, stock HO Intake, and stock HO round port manifolds. There were zero problems with power brakes, even with the low compression and standard lifters. This was back in the late 90's/early 2000's, and looking back on it now, there was alot of potential left on the table with that car. Had a real nice idle around 750-800 RPM that I would describe as "Racy", not "Rough" or "Lopey". He ran 3.42 gears, the factory TH400 beefed up internally and a TCI Breakaway(2400 stall) converter in it.
1978 Trans Am Pump Gas 461 Stroker |
He ran H-O Racing. There is your insight on the parts you have. Just ask him. Back in 1982 when I bought my 69 GTO I went to a local shop and asked him "how do I make this thing go faster? " He told me "put a BBC in it". I turned around and walked out, never spoke to him again. Went out and found High Performance Pontiac magazine and looked at the adds. I found Nunzi Rons Pontiac. Bethel,s Goat Farm. Rock and Roll Engineering. Crane Cams. Comp Cams Jim Taylor. Whitmore Engine Service. Dan became my Pontiac mentor. Jim Butler. (Dan was his first machinist) And H-O Racing. Bought catalogs from Rons, Nunzi, R&RE, Jim Butler and became friends with Dan And still have My H-O Racing catalog, Torker Tuning Secretes, HD parts and Specs books. And worn the Pete McCarthy SS book to pieces. Good times. And still hate Chevy,s in Pontiacs. |
The amount of overlap shown in post 9 is that same amount as a factory RA4 cam.
Thread Tools | |
Display Modes | |
