Finally I feel like messing with my car again
I finally felt like messing with my car again and have been assembling my engine.
I got the heads on and decided to throw on some intakes I have sitting around. I will use the Victor with a single dominator, but the Wenzler with dual dominators sure does look mean. Robert
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4. |
I need to figure out what cam I want to run now. I have 3 solid rollers I can choose from and on large solid flat tappet.
I have a UD grind Solid roller that is Grind number 304 310 R6 and another number of G3984 is on the end. I am trying to find the specs on this cam as I bought it used from a member on here The UD solid flat tappet is 308-316 F8 and the duration at .050 is 275 and 282. The lift is .649 and .654 with a lobe separation angle of 108. A lunati SR with 93G1A and 28935 stamped on the end. I lost the information on this cam when my computer died. I also bought it used from a board member. The final cam is a comp solid roller with grind number of 305-2 305-2 R10. On the Comp cam site the duration is 272 @ .050 with a lift of .622 on a 110 Lobe separation angle. My heads flow is as follows. lift......Intake......Exhaust.....% 100....77.1..........62.6.........81.1 200....150.6.........114.6........76 300....204.9.........152.9........74.6 400....250...........177.9........71.1 500....288.2.........200.3........69.5 600....319.1.........226.6........71 700....336.8.........237.7........70.5 Car is a 67 Firebird weighs 3600 lbs and I am running 4.10s now, but my new rearend has 3.73s. Robert Rife
Thread Tools | |
Display Modes | |
