Old 01-19-2022, 02:04 PM
ponchorob ponchorob is offline
Default 428 street strip gear
428 with 13 heads 60919 cam rhoads lifters 9.6 compression. 67 firebird 2500 Converter... thought about using a 3.90 gear...for street strip.... if a take or go back to 3.42 ill think i would runner slower maybe 0.3 to 0.4 s..... so what do guys think about 3.42 vers 3.90 gears on my combo
Old 01-19-2022, 03:34 PM
I'd say the 3.90 would be more strip than street.
3.42's would make great street and some strip or even more strip.
Old 01-19-2022, 03:47 PM
Mike Davis's Avatar
3.55 or 3.73 works well with a 4" stroke.
I switched from 3.73 to 3.90 to 4.10 and noticed very little difference in ET.
Roughly less than a .10 between the 3.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
The Following User Says Thank You to Mike Davis For This Useful Post:
Old 01-19-2022, 04:01 PM
nas t eh nas t eh is online now
Three speed auto or four speed overdrive? 3.42 if turbo 400, 3.90 if you have an OD trans.
Old 01-19-2022, 04:10 PM
Have a th400 ....
Old 01-19-2022, 04:25 PM
Have a th400 ....
Old 01-19-2022, 04:34 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
3.42 plus adv +4 on the chain...
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th
66 Star Chief Executive 57k mile
69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
2019 Chevy Spark petrol car 38 mpg
Old 01-19-2022, 04:49 PM
Have a th400 ....
3.90 is rather short for hyway speeds on the Street, stick with 3.42
Old 01-19-2022, 06:28 PM
dragracerx2813's Avatar
dragracerx2813 dragracerx2813 is offline
What Mike Davis said.
Old 01-19-2022, 06:56 PM
Mike davis 3.73 to 4.10 results are interesting but maybe his converter stalls a lot higher than mine...so theres not so much difference
Old 01-19-2022, 07:18 PM
....i mean with my 2500 converter it should run a lot faster with 3.90 vers 3.55 but maybe im wrong..
Old 01-19-2022, 07:59 PM
Mike Davis's Avatar
I have a 5200 Converter in my 66 with the 421.
When it was primarily a street car I had a 3500 in it and a 3.73 gear. Was a good combo for around town and short drives.
With the cam shaft you are running I'd go 3.55 if you can.
My 67 has a 428, #62 casting heads, 66 Tri Power, Ultradyne Cam similar to the 60919, TH400 with a 2700 Converter, 3.55 gears with a 27" tire. I like the way it cruises on the highway. I would not want much more than that.
Old 01-20-2022, 04:34 AM
Guys thanks fot all your opinions an Mike thanks for your detailed info ..
Old 01-20-2022, 08:53 AM
see 12.24 ET signture, only combo diff is the stroke.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 01-20-2022, 02:52 PM
RBAILEY RBAILEY is offline
Old 01-20-2022, 02:54 PM
3.42 good choice for street strip.....3.90 is too low..w/TH400. If your tire height is anything shorter than 28 you'll be hating life on the freeway with 3.90s, and even with 28s its not fun on the freeway with 3.90s
Old 01-21-2022, 01:26 PM
Mike your 67 428 with 3.55 gear have you ever run on the track any quartermile results....?
Old 01-21-2022, 01:49 PM
Mike Davis's Avatar
I have not run the 67 in a long time or with this combo. Just basically a cruiser now. It has been in the family since new.
The last time the car was ran, my Dad ran it in the 90's. Combo was 428 std bore, 068 cam, stock 670 heads, Ram Air Manifolds, 67 Q jet intake and carb, TH400, 3.55 gear. Car ran 12.70's.
Old 01-21-2022, 03:32 PM
Gear vendor would allow you to run more gear and cruise on the interstate.
