#41
How about this "the sky is blue" thing? Man that gets me mad! IT ISN'T REALLY BLUE!
You people need to get a life. Change it HOT you chicken$h!t$! LOL! |
#42
The funny part about this post is I actually read the whole thing. LOL
Tim Corcoran |
#43
Why even change it? Do like my boss with regards to servicing my Freightliner truck, 390,000 - oil and filter changes costs the company money and reduces his yearly bonus if he increases company equipment spending. We don't change oil or filters, just add oil when it gets a gallon low. The oil is a bit thick & black, but the oil pressure is still good and it doesn't burn it, so rings must be OK. Just keep your RPM's low to keep wear down. This way draining the oil hot, warm, or cold never comes up as an overthought issue or in conversation.
#44
Lol I retuned one because I got the wrong Vis, I take it back and the guy opens it, I said now it’s no good.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8” Flakes F ire B irds 🇮🇱 |
#45
You don’t warm up the oil you put back in, it comes out of the can just fine. I don’t recall ever 1/2 can of oil that won’t come out, Or do you guys warm up, your cans of oil too
#46
Before I put oil back in my engine I will always put a few drops on my wrist to check temperature
2 drops is not nearly enough and 4 drops are way to much
A man who falls for everything stands for nothing. |
#47
My point was--removing the drain plug when the engine is warm will allow suspended contaminants to drain with the oil instead of allowing contaminants to settle to the bottom of the pan. This really is becoming a tough group--stating one's opinion gets similar results as posting on a political site. We're here to help each other, not to be trolls.
#48
462 Yc Block, zero deck Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR Comp Hyd-roller cam,roller lifters,springs ect. 236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6 Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut Powerjection3,T2 manifold, Try-y’s Flowcooler water pump. 71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire. 17x9 YO Honeycombs with Nitto 555's |
#49
The best way to rid the left over oil is to build a bonfire under the oil pan to burn off the remaining oil. What will be left is ash and contaminate particles and then by inserting a high pressure air hose into each valve cover, the remaining ash will blow out the drain plug. DO NOT install the drain plug when blowing out the ash as it will balloon the oil pan and you won't ever get a true reading of the oil fill level on your dipstick - ask me how I know this. |
#50
#51
No biggie. I won’t ask any more questions.
#52
So how much oil does a Pontiac head hold? 40 CC's per head. https://www.gtoforum.com/threads/how...1/#post-905521 |
#53
Just a wild guess, that sure looks like Smokey Yunick's boots, and pit uniform in the picture. I know exactly why he's warming up the oil, because back in the day racing oil was like molasses, and he's trying to make it pour quicker during a pit stop.
They didn't run dry sumps back then, and 5 quarts wouldn't make the entire 500 miles without adding to the engine during a race.
Brad Yost 1973 T/A (SOLD) 2005 GTO 1984 Grand Prix 100% Pontiacs in my driveway!!! What's in your driveway? If you don't take some of the RACETRACK home with you, Ya got cheated |
#55
See ya
#57
That's a classic pic, I've seen it before. Back in the day when Pontiac was "allowed" to race by GM. I read Smokey's cars had 3" main blocks with cut & welded 421 cranks.
65 Tempest, 400, TH400 86 Fiero SE 2.8 |
#58
Closed Thread |
