tomahawk ultra lite rods
Ace if your out there,how lite are they? thanks joe
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119 |
My tomahawk billets were lighter than Ace said. I think they went 763, he spec them at 772? 6.8 bbc rod end. Shop said they looked good.
Ace if you are out there i have been trying to PM you. please contact me.
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
So what is that about 30-40 grams lighter than a stock caast rod?Dosen't sound too much lighter.
I believe a stock cast rod is around 890, and a Eagle is around 800. So, there is quite a bit of difference. |
I didn't know it was that much.mmmmm
30 grams is alot at 6800 rpm!
I have updated my website. I will update the rods with aproximate weights. And if you look at my website. I am open to sugestions.
Thanx, Ace
Am I glad I got out of the business I was in? HELL YEAH!!! |
I dont know if its just the picture or what but those caps sure seem thin, anyone know the thickness compared to other rods?
The reason why I am asking is that I'm building a 400 and using a 350 crank.Going light all the way.Toss up between aluminum BME or lightened rods via Ken the Ace man.
The BME's are around 600-660 grams Depending on Length ect, The Tomahawks are wayyy More than Most will need for Street use, Yes I have had a set to look at and They are a Very Nice Rod especially for the $, If it said Crower or Oliver it would be 700$!, You will never need BME's on the Street in a 350 IMHO, Plus Ballancing can get Expensive, Your best Bet to a Good Quick revving engine is Lightweight Forged Pistons and Decently light rods, Whatch Piston pin weight too, I like Ferrea's 90028 .990 pins 130 grams and Forged taper wall design Personally, So Tomahawks Would do Whatever you want short of I'd say 750hp max
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines! 2006 silvy Z71 4X4,383 LS 600+hp NA Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-} |
how mutch do the BMR rods weight in at compeard to i beam and h beam rods
